Is it worth the $ for Rapid Fire spark plugs, or are Champion just as good? It's a 1976 L-82/m-21.
Opinion: You are comparing apples/oranges! Long ago, Champions were a fine plug and I put them in my and everyone elses car I worked on. These days (recent history), I have had and heard about many problems with Champions just not holding up.
If you don't want to pay the extra $$ for the Rapids, then I would recommend standard AC plugs. They are very good.....still.
From: Exiled to Richmond, VA - Finally sold my house in Murfreesboro, TN ?? Corner of "Bumf*&k and 'You've got a purdy mouth'."
CI 6-7-8 Veteran
CI-VIII Burnout Champ
St. Jude Donor '06-'10, '13
I love the Rapid Fires. Every car that I have installed them in I have noticed a smoother idle and maybe - just maybe - a bit better off-idle performance. But they definitely have always produced a smoother idle.
Thank you for the info, I had no idea Champion plugs were lousy. So either buy regular AC delco, or the Rapid Fire. What about platinum vs non-platinum?
Platinum generally last longer (hence the reason why a lot of the new GM cars don't require new plugs until 100,000 miles). I'm not saying that those plugs won't last 100,000 miles in your vette, but the one thing about them is they don't lend themselves well to gapping. In fact, when I used to sell them, they came pre-gapped, and you weren't really supposed to touch them with a gapper. Platinum is hard, but can be brittle (if i remember right, my metallic chemistry is a little weak). Honestly, I'd run the R44TS or whatever the standard AC plug is for that year. They hold up just fine, can be regapped when necessary, and have always worked fine for me.
CI 6-7-8 Veteran
another problem with platinums is when you run more voltage through them than they were intended for. From the experience we had with Bosch I was not happy. We had a hotter coil on a Shelby GLHS turbocharged engine and the plugs went to crap within 3000 miles. A call to their customer service group and a call back from a product rep. informed me that the additional power, the boost from the turbo, the higher heat environment caused more resistance in the "wire" that is normally a much larger electrode. This resistance with the additional power causes them to overheat and melt the wire or cause it to crack internally.
