March pulley clearance
Old Apr 7, 2005 | 02:09 PM
Lohkay's Avatar
Lohkay
Default March pulley clearance
Hi,
Could anyone give me a hand and check for the clearances to the frame/suspension with the specs given in this url? My vette is far and won't have access to it till this weekend and I really need to order this asap if it fits. I'm pretty sure the PS pump will be fine but I'm not sure about the alternator. It will be installed on a '78 SB w/o AC.
March Pulley
Thanks in advance, I owe you one!
Old Apr 7, 2005 | 03:25 PM
7t2vette's Avatar
7t2vette
The ORIGINAL and bestest
Toronto Events Coordinator
I have the March kit on my car, a 72, and there are no clearance problems. The link you posted is for a long water pump, you need a short water pump kit on your vette. This is the kit you need, the same as on my car:http://www.marchperf.com/pg13.html
You can see it in my avatar pic
Old Apr 7, 2005 | 04:45 PM
c3-4me's Avatar
c3-4me
I just put this same kit in my '80 and there is no clearance issues. The only thing I will have to do is get a plate of some sort to go between the belt and the upper rad hose as there is only about 1/4" clearance.
Old Apr 7, 2005 | 05:15 PM
ToddHunt1973's Avatar
ToddHunt1973
I just put a march kit on my 73 454. If you cant find what you are looking for call summit Bp's extension is 6595 he helped me out a ton.
Old Apr 8, 2005 | 08:44 AM
Lohkay's Avatar
Lohkay
Bummer... I really liked the looks of the kit I was looking at.
Old Apr 9, 2005 | 06:10 AM
ToddHunt1973
Instead of using the stock radiator hose you should try the flex aluminum hose that will allow you to move it away from the belt.
To March pulley clearance
