What sized socket for brakes??
Old Apr 7, 2005 | 02:54 PM
BSeery's Avatar
BSeery
From: Exiled to Richmond, VA - Finally sold my house in Murfreesboro, TN ?? Corner of "Bumf*&k and 'You've got a purdy mouth'."
CI 6-7-8 Veteran
CI-VIII Burnout Champ
St. Jude Donor '06-'10, '13
Default What sized socket for brakes??
I am trying to pull the front calipers off my 1980, and I can't seem to figure out the size of the socket needed. I have tried a 19 and 21 metric and those don't fit. I have also tried my standards and one is either too loose or won't fit.
What the heck size are these bolts ????
Old Apr 7, 2005 | 04:46 PM
SLine78's Avatar
SLine78
Should be 5/8". Van Steel recommends using a sparkplug socket on a breaker bar.
Mike
Old Apr 7, 2005 | 05:04 PM
Sharky Guam's Avatar
Sharky Guam
Yep, it is a 5/8 socket. Do not use one that has a thick wall. The caliper castings around the bolt hole will not allow you to use one that has a thick wall. So impact sockets or some 6 point designs just won't slip in. I use a thin wall spark plug socket to remove mine. The bolts are not that tight.
Old Apr 7, 2005 | 05:08 PM
BSeery's Avatar
BSeery
CI 6-7-8 Veteran
Hey thanks !!
I was trying with impact sockets and some regular sockets, but I do have a special thin wall 5/8th" for spark plugs.
To What sized socket for brakes??
