Need Help From The Electrical Experts
Old Apr 7, 2005 | 06:38 PM
es's Avatar
es
Default Need Help From The Electrical Experts
The '81 has a small but irritating problem (I hope it's small). When the lights are on the right turn signal indicator glows at about half brightness. Use the signal and it flashes properly. The first time I had this problem it went away when I replaced the burned out right turn signal bulb. Now a month later it is doing the same thing but this time the bulb isn't burned out so the previous bulb replacement "cure" may have been just coincidence. Every light on the car works properly. Where do I look and does this indicate something major? I hate to see the old girl burn to the ground.
Old Apr 7, 2005 | 07:30 PM
Sharky Guam's Avatar
Sharky Guam
Check the bulb connections and the ground wire that goes to that particular bulb. apparently, there is a bad ground to that bulb and is causing that bulb to draw part of it's ground through the indicator bulb circuit. That fix should do it. If you can, put a multimeter to the contact on that bulb and check the ohm reading to make sure that you have a good ground to that particular light circuit. This particular problem poses no danger of an electrical fire.
Old Apr 7, 2005 | 08:19 PM
es's Avatar
es
That makes sense to me. When I changed the bulb I probably moved the ground wire to a "just right" spot that made things work correctly for awhile. Great info. Thanks for the help.
Old Apr 7, 2005 | 09:41 PM
NHvette's Avatar
NHvette
Also, did you check the front AND rear ?
Old Apr 7, 2005 | 11:06 PM
VETDRMS's Avatar
VETDRMS
Mine does the EXACT same thing, VERY frustrating.
I'm not alone...
Old Apr 7, 2005 | 11:40 PM
79ls1's Avatar
79ls1
I run into this all the time. It is probable that you temporarily restored the connection when you replaced the bulb by disturbing it. That would mean a bad connection at the socket or a bad socket. Connect a multimeter as Sharky described and wiggle the wires or you can even just leave the bulb in with the lights on and wiggle the wires and see if the problem changes.
Old Apr 8, 2005 | 04:36 AM
matthud's Avatar
matthud
I had a similar problem, the bright indicator was reversed and the speedo lights didnt come on. It turned out that the ground for the cluster was disconnected. Re-attached it, and all was well.
Old Apr 8, 2005 | 06:19 AM
mrvette's Avatar
mrvette
All olde car electricals are primarily the same, and i'ts a common enough problem with any 60's-70's car, light bulb corrosion, use some WD40 or better yet, electrical contact cleaner, on the sockets, and secure all ground wires this crap gets silly allready with all the ground wires on account of plastic body....all the ground wires are black....
GENE
To Need Help From The Electrical Experts
