Need Help, Strange sound
Old Apr 7, 2005 | 07:50 PM
Mr Chauffeur's Avatar
Mr Chauffeur
Default Need Help, Strange sound
While going for a quick ride this morning, from a starting stand still, I got on it a little bit. Immediately upon depressing the accelerator, a grinding sound occurs. But it only lasts for a second or two and doesn't occur again through the cycle of gears. The only time I am hearing this grinding rattling sound is at initial accel. What is this? It seems as though it is coming from the rear of the engine compartment but I can't tell where exactly. It sounds as if it's rocks being flung about from the tire spin but it's coming from the engine compartment, not the rear end. Any ideas?
Old Apr 7, 2005 | 08:07 PM
MEGALADON's Avatar
MEGALADON
From: WAY DEEP INSIDE AMERICO,YES YOU LIVE HERE TO!! TX
Sounds weird , but im sure someone here can help
Old Apr 7, 2005 | 10:08 PM
Jclgodale3's Avatar
Jclgodale3
fan hitting the fan shroud? Check for evidence...if so, broken drivers side motor mount...just a thought
Old Apr 7, 2005 | 10:17 PM
chris75stingray's Avatar
chris75stingray
upon acceleration, you can get a rattling can sound if the timming is retarded too much.
Old Apr 8, 2005 | 12:32 AM
rihwoods's Avatar
rihwoods
Could be the dust cover to the bellhousing.You describe what I had once,after putting in a new clutch. The tabs got bent slightly and came in contact with the flywheel but only at just taking off.
Old Apr 8, 2005 | 05:54 AM
Mr Chauffeur
Could I have a bad fan clutch?
Old Apr 8, 2005 | 06:25 AM
78 anny vette's Avatar
78 anny vette
need more info, 4spd or at
Old Apr 8, 2005 | 10:50 PM
vetteguy75's Avatar
vetteguy75
LA Events Coordinator
I thought the rattling was if the timing was to advanced...am I wrong?
Old Apr 9, 2005 | 09:15 AM
American Boy's Avatar
American Boy
A broken rubber engine mount would cause the fan to hit the shroud on start. It's real easy to check. Lift your hood, start the engine, hold the brakes and press the gas pedal (if automatic) until the car want to move foward. If manual release the clutch until the engine want to stall. If it's loose, the engine will move upward and the fan will hit.
Stephan
Old Apr 10, 2005 | 07:29 AM
Mr Chauffeur
Thats it. Thanks everyone! It is indeed a broken motor mount. Good diagnosis American Boy!
To Need Help, Strange sound
