Use an internet search engine for Tom's. The February Hod Rod Magazine had an article about Tom's pretty much bullet proof IRS set up for Corvettes. I've bought a bunch of stuff from them (Tom and Ken) and have been very pleased.
Anyone know where I can get a crush sleeve only for a 74 10 bolt gm/eaton differential????
GM or Raytech I think I have one in my stock. PM me and I'll check. It will cost you what ever I paid + UPS. I'm guessing they were about $6-$7? Solids with shims run about $30 for comparision, unless you can make one up.
Gary
I would never use a crush sleeve again. The solid spacer is far superior and if for any reason you have to pull front off the pinion for changing a seal with a spacer it is very easy.
Putting the proper preload on the crush sleeve is also very difficult.
Spend the money and go with a solid spacer.
Gary
THANKS Gary, in the mean time I found one for 8 $ on ebay I sent a request for your rebuild paper -Never can do enough reserch. the bearings and spacers I'm ok with -the clutches and spr ings I'm still a little iffy on.
