.015 Head Gasket vs Pushrods
Can a too long pushrod contribute to or cause valve seal problems? If the pushrod is too long would it be slightly askew at the guide allowing oil seepage?
I have +.100 (.080 wall chromoly) pushrods which were recommended by TFS for their Twisted Wedge heads. I sold the TFS heads and installed WP Sportsman II's. I never changed the pushrods or checked the geometry other than visually. I've always had an oil seal prob with the Sportsman II's, first with their umbrella seals and then with teflon seals.
Since I changed the head gasket ( I had some port work done and new teflon seals installed) the problem seems to have gotten worse. But it only has the problem on some cylinders, not all.
It should start one side of the valve stem and move an equal distance to the other side then back. If this is off a little, not too much to worry about, if it is off alot it will result in premature valve guide wear amongst other problems related to side loading the valve.
So yes, it will cause oil consumptin problems and no, you would not neccessarily have to change the pushrods when you change the thickness of the head gasket but I would check it.
BTW it was you doing the Rip van Winkle on the AR motor wasn't it, I never heard anymore about the motor ?
But the latest Chevy Performance seals like those used on the ZZ4 and fastburn heads are softer than teflon but stay on the guide and have read good results with them. Ok, called PC seals i think.
Have u tried a p-rod length checker? Only $10 from Summit (made by ProForm and Moroso). Easy to use - just follow instructions. Summit also sells custom length p-rods (Trick Flow) and i bought mine for <$90. This should get your rocker tip to travel from top 1/3 of vlv tip to lower 1/3 and back and as long as it stays off the edge it won't create side-loading on vlv stem and ruin the guides. But if the guides are aready ruined noth'n gonn'a help.
This a common problem/topic on the forum and u may want to do a scearch and review several posts.
Good luck. cardo0
It sounds like you and I are in the same boat. I am not sure what can be done, but as I sort through mine I will update you. Try and keep posting to this tread if you have any updates.
My heads are off the motor now and will be at the machine shop next week.
Good luck
Push rods are sold in .050 increments. Unless your get custom.
If you had the same heads and just changed gasket and you lost .030 your going to be off in length that amount. Also the base circle of cams is the big difference. I went from a Crane small base circle .930 inch to a Comp Cams 1.030. I had to change from .250 over length to .150 over length.
