3/8th hose
Old Apr 9, 2005 | 08:25 AM
foundvettelifeisgood's Avatar
Default 3/8th hose
Is the 3/8th hose from the overflow tank to the radiator special? I bought some 3/8th from the parts store that is essentially fuel line. It's got the imbedded fiber braid, but it's not as beefy as the original hose.
I'll be driving the car a lot today and I don't want to find out the hard way that their is special 3/8ths heater hose that I need for this run.
Old Apr 9, 2005 | 08:41 AM
norvalwilhelm's Avatar
norvalwilhelm
That hose doesn't see pressure, it just moves water from the overflow to the tank and back under a slight vacuum. It does see heat but that is no big deal. Is it really 3/8th inch?? That seems big to be sliding over the little nipple on the overflow??
They don't clamp this hose to the overflow so the hose needs to be a tight fit.
Old Apr 9, 2005 | 12:47 PM
Norval--Thanks for the reply. There was a clamp on it, and I left the clamp on it. I just drove the car for about 2 hours, and no sign of trouble.
I would think there would be pressure, because the overflow tank has pressure at temperature.
Old Apr 9, 2005 | 11:51 PM
yellow 72's Avatar
yellow 72
St. Jude Donor '09
You're talking about the hose from the rad to the expansion tank. That hose has cooling system pressure and good quality fuel line will work fine...Norval's "late" model has that new fangle system
To 3/8th hose
