Compression test results.
Old Apr 9, 2005 | 10:36 PM
VETDRMS's Avatar
VETDRMS
Default Compression test results.
I have spent the last 3 days getting the car all ready for racing season (hopefully the track will open next week), and have been tracing down a timing problem among other things. I was setting the hot valve lash and figured I'd do a compression test to see how things are doing. The shortblock has approximately 10,000 very hard street/strip miles. I am very happy with how the came out. The highest variance between cylinders was 3%.
Results:
Cylinder - PSI
1 - 180
2 - 183
3 - 180
4 - 186
5 - 182
6 - 186
7 - 182
8 - 185
Old Apr 9, 2005 | 10:52 PM
bobs77vet's Avatar
bobs77vet
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
looks good....you must be happy..... just out of curiosity what is your cam specs and final CR
Old Apr 9, 2005 | 11:18 PM
VETDRMS's Avatar
VETDRMS
Cam Specs: Comp XR 280-R: 242/248 @ .050; .570I/.576E; 110LS; 106CL
Static Compression: 10.7:1
Old Apr 9, 2005 | 11:30 PM
ZL1powr's Avatar
ZL1powr
VETDRMS those are very consistent.
Old Apr 10, 2005 | 12:15 AM
Les's Avatar
Les
Great numbers- you, sir, have a very healthy engine. Good luck with the new season
Old Apr 10, 2005 | 12:18 AM
GrandSportC3's Avatar
GrandSportC3
Cruise-In IV-V-VI-VII-VIII Veteran
St. Jude Donor '03, '06, '17
looks like your engine is healthy!!
Old Apr 10, 2005 | 12:40 AM
mandm1200's Avatar
mandm1200
I was thinking you had a problem when I saw the topic.
Guess you were bragging! Doesn't get any better than that.
Anyway, those are great numbers and very good 1/4 mile times to boot.
Old Apr 10, 2005 | 03:01 PM
cardo0's Avatar
cardo0
From: Las Vegas - Just stop perpetuating myths please.
Default Did u change cams?
Results:
Cylinder - PSI
1 - 180
2 - 183
3 - 180
4 - 186
5 - 182
6 - 186
7 - 182
8 - 185
Looks like ur c.r. could be higher and still use pump gas if u have good cyl quench. Those numbers would be much higher with a smaller cam/less overlap. Looks like u changed to a tighter LSA cam? Which is ur Lobe Separation Angle - LS or CL? 110 or 106?
Okay i'm no expert so u should do ur own research but D. Vizard says u can run at least 200 psi for street machine and up to 220 psi for street/strip mtr and use the pump gas.
Just my blab'n but looks like u could go to a shorter duration cam and maybe make the same or better power while more tame driving around town. Please don't shoot me because i know those roller cams ain't cheap but when u get down to durations around 270* there is no advantage to a roller.
Well those cyl press do look like the bottom end is nice and tight. cardo0
Old Apr 10, 2005 | 03:12 PM
VETDRMS's Avatar
VETDRMS
Thanks cardo, lobe seperation is 110 installed on a 106 intake centerline. I will not try to push the 91 octane pump gas too far here. A margin of safety is acceptible.
Quench is "good" at .039". I spent $400 on Cometic head gaskets getting it!
Are you referring to no advantage at .050 duration less than 270? I would beg to differ in that regard. Seat duration is 280/288 with this cam. I ran a comp XR288 hydradaulic roller with .050 duration of 236/242 compared to the current 242/248 and the car runs stronger with the solid roller. The area under the curve and duration at peak flow is higher than a flat-tappet/h-roller. The benefit is keeping the valve in the peak flow of the head longer while using less seat duration. I drove this car 700 miles last week.
Driving is perfectly tame, no issues at all.
EDIT: The Dynamic Compression Ratio calculated using Smokemup.com's calculator is 8.5:1.
Old Apr 10, 2005 | 04:23 PM
cardo0's Avatar
cardo0
Default Full duration as 270*
:o I should have said full duration and yes this is a general statement as total flow area with vary with manufacture and cam intensity. I don't recall the dynamics of this but do remember 270* full duration is the trade-off point where rollers begin to walk away making more power and by 280* its no longer a match.
But if ur happy with what u have then i'm happy for u. It sounded like u were asking for advise/opinions and u got mine. Myself i like the lower c.r. engines as they seem to live forever - at least the bottom end. The hi c.r. with hi rpm makes more pwr but seems to break more mtrs at the strip. Just what i seem to observe.
BTW i thought i was still buying/finding 93 oct at the pump? Haven't bothered to look while pumping. All brands down to 91 oct? cardo0
Old Apr 10, 2005 | 05:38 PM
81 Vette's Avatar
81 Vette
St. Jude Donor '05
First C3 General Poster!
Not in Canada, we can get 94 Octane
Old Apr 10, 2005 | 07:55 PM
VETDRMS's Avatar
VETDRMS
Cardo: Thanks for your opinion, if I had both the time and extra cash I would go with a belt drive and swap cams, heads, cars..ect ect. I may be leaving a little on the table, but from my research this cam was best suited to my setup.
Yes, in Montana you can only get 91 octane.
Old Apr 11, 2005 | 03:42 AM
TLChydraulics's Avatar
TLChydraulics
maybe someone could help me with a problem...... I have a 67 GTO 421 with flat tops, ram air 4 heads, and the previous owner milled the block, heads and intake, bringing my compression to 270 psi per cyl. It runs like a raped ape, with enough acetone in the gas anyway, but I have to replace my head gaskets every 2-3 weeks of racing her. everytime blows the gaskets out between the cylinders. I have tried every brand of gasket I can find, and I get 2-3 weeks of race time. I haven't ran the car now for about 4 years, cause it gets old working on it every other week. I just want to run it, have some fun. I have not a clue where I could find those heads again, and really don't want to spend that kind of money anyway. Is there a place to get extra thick gaskets? or something to get the compression down? I did have eyebrows cut into the pstons out of neccessity when I first got this engine, as the valves bent hitting the pistons. It took me a couple months to find enough new valves to repair the heads. Apparently the ram air 4 heads were an after-market no longer made after 69 and are very rare.
Loren
Old Apr 11, 2005 | 06:39 AM
SmokedTires's Avatar
SmokedTires
Cruise-In III Veteran
St. Jude Donor '05
TLChydraulics: check to see if Cometic gaskets has anything for your application. They're not cheap, ask VETDRMS , but I've heard of people not having to o-ring their boosted engines (high cylinder pressures) when going with these gaskets.
Very nice pressures VETDRMS I'm probably going to pickup a compression tester also before I put my engine back in
Old Apr 11, 2005 | 09:45 AM
mandm1200's Avatar
mandm1200
TLChydraulics:
One option to lower the compression is to take the pistons out and have a little bit of the tops milled off, or go with dished pistons.
Old Apr 11, 2005 | 11:05 AM
VETDRMS's Avatar
VETDRMS
Loren: You may want to give Cometic a call. A fair bit of the LSX guys use them in boosed applications. I got them to reduce my quench and maybe run a little nitrous.
http://www.cometic.com/
The custom sets are $180, but just make sure you order the right custom dimensions (don't trust the salesmen when he says they will work), or you'll be buying another set...
Mike: Thanks, how are the modifications to the heads going? I would like to see some pictures if you have any.
Old Apr 11, 2005 | 11:52 AM
SmokedTires
St. Jude Donor '05
I'll take some pics, never thought of doing that. The last I heard, the shop hasn't touched them, but I'm going to start putting some pressure on them or I'll have to find someplace else that can to it
To Compression test results.
Old Apr 11, 2005 | 12:30 PM
VETDRMS's Avatar
VETDRMS
Mike: Those guys just seem to be way too slow, I'm surprised yoru still going there. I am fortunate enough to be good friends with my machinist, I would go nuts not being able to walk in and check out all my stuff on a daily basis!
Old Apr 11, 2005 | 03:56 PM
gkull's Avatar
gkull
Were are kind of running the same cam, that is if you have XR280R
Solid roller with 242/248. If it's the same you must have a noticable idle. I've set mine at 950 rpm and I was pleased to tweak in the four idle screw until it got a stead 13 inches of vacuum.
I went with 10.7 static with a .021 thick copper gasket.
Old Apr 11, 2005 | 04:11 PM
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
I have the same cam and 11:1CR I will check my cranking pressure this week. My 355ci cubic in. L48 had cold cranking 230-235 psi with the Sportsman II iron heads and ran like a champ anything above that you are looking for trouble.
If you have 270psi and it is a racing motor then the simple solution is put in more cam, you probably don't want more than about 240psi
