small block to big block
Old Apr 11, 2005 | 12:52 PM
68vetteracer's Avatar
68vetteracer
Default small block to big block
How hard is it to but a big block chevy in a 69 corvette that originally came with a small block. What are the necessary changes that need to be done. any help would be a big help
Old Apr 11, 2005 | 01:25 PM
Jughead's Avatar
Jughead
Senior Member since 1492
From: Just because I'm paranoid doesn't mean people aren't out to get me...
St. Jude Donor '09
Very popular topic. Have been lots of posts on the forum. Try a search first. These links might help you out. Briefly you'll probably need to replace the radiator & shroud, hood, front springs and all those pulley's.
Hard? No it wasn't hard and this was my very first complete engine rebuild and swap. Its time consuming and expensive.
http://diabolicalperformance.com/c3bigblock.html
http://temp.corvetteforum.net/c3/197...y/index4.shtml
http://temp.corvetteforum.net/c3/the...t/index9.shtml
Old Apr 11, 2005 | 09:17 PM
zacs1946's Avatar
zacs1946
my 69' vert came as 350....now it's a 461...popular swap..but it is time consuming and expensive. Nothing from the small will except the dis.and starter will work. Like the previous post, rad.,fan shroud,springs, trans, (unless you have a turbo 400),power steering, pullys, rad. overflow, and many other little odds and ends. But, for me it was well worth the time and effort. Nothing in this world like a built big block vette.......
To small block to big block
