starter solenoid?
Old Apr 11, 2005 | 06:03 PM
71redskin's Avatar
71redskin
Default starter solenoid?
i found my positive cable shorted to my exhaust... but b4 i found it i tried to jump it a couple times. now that i've fixed the problem, when i tried to jump it all i got was click click....is my solenoid fried and how do i check it....
Old Apr 11, 2005 | 11:23 PM
vetteboy1976kr's Avatar
vetteboy1976kr
If the car sits for a while (like mine) sometimes the solenoid sticks and won't push the bendix gear out. Tap on it with a hammer a few times to se if you can loosen it up, or wail on it with a dead blow. It also could be that you need to let the battery charge for a couple of hours or the terminals are dirty. Check these before replacing the soleniod.
Old Apr 12, 2005 | 01:48 PM
71redskin's Avatar
71redskin
Default solenoid
i installed a new battery and it started right up... now on to setting timing, dwell and carburater and seeing if the rear wheels can keep up with this 454
To starter solenoid?
