instrument light help..
Old Apr 12, 2005 | 03:00 AM
c3 in hawaii's Avatar
c3 in hawaii
Default instrument light help..
I have replaced the speedo/tach circuit along with the fuse and all bulbs...the instrument lights work on the center console gauges and the shifter lense, but I got no lights in the speedo cluster... left turn signal doesn't illuminate, any suggestions would be greatly appreciated..
Old Apr 12, 2005 | 07:06 AM
EDDIEJ82's Avatar
EDDIEJ82
Check the ground. Mine did the same thing and it ended up being a loose ground I forgot to hook back up. It's way up under there, sorry I don't remember exactly where it was, but I remember it was a bitch to get to.
Old Apr 13, 2005 | 02:08 AM
c3 in hawaii
Thanks for the info, it may be that considering I had the interior completely removed for paint and probably pulled a ground wire without realizing it, guess I gotta pull the dash again.
Old Apr 13, 2005 | 09:58 AM
oregonsharkman's Avatar
oregonsharkman
just went through a similar thing with my gauge light in the center
good luck
To instrument light help..
