Fuel Leak somewhere on Fuel Pump
Old Apr 14, 2005 | 10:36 AM
jaketerk's Avatar
jaketerk
Default Fuel Leak somewhere on Fuel Pump
I've been smelling gas lately so I put the car up on a lift to find that the fuel pump and surrounding areas are wet with fuel. I cleaned off the fuel as best I could, tightened the fuel lines to the pump, and tightened where the fuel pump attaches to the block. Keep in mind, the hoses are new. I started the car and checked to see if I could see where the fuel was coming out, but i couldn't see anything maybe because it doesn't leak at idle because the fuel pressure is low (assumption). So the question is: Are there any tricks for locating a fuel leak?
-Jake
Old Apr 14, 2005 | 10:38 AM
bobs77vet's Avatar
bobs77vet
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
-Jake
is it above or below the crimped halfway mark? look for the little vent hole on each side just above the crimped section its about the size of a 3/32 drill bit....see if that is the source....
Old Apr 14, 2005 | 10:56 AM
jaketerk's Avatar
jaketerk
So your talking about a vent hole on the actual fuel pump itself? If that's the source, does that mean I have a faulty pump?
Old Apr 14, 2005 | 11:03 AM
bobs77vet's Avatar
bobs77vet
yes it means your internal diaphram is leaking and the fuel pump needs to be replaced before it ruptures and pumps gas into your engine through the push rod mounting plate....thats a real bad thing....
Old Apr 14, 2005 | 11:05 AM
jaketerk's Avatar
jaketerk
Would that occur at idle, or will it only occur when your throttle is depressed significantly?
PS: Thanks for your help!
Old Apr 14, 2005 | 11:36 AM
Matt Gruber's Avatar
Matt Gruber
considering the fire hazard, and the low cost of a new pump, i suggest you run it until the car is in flames, and post pics to entertain us
Old Apr 14, 2005 | 11:38 AM
1970 Dave's Avatar
1970 Dave
100%---now why would I know that?????
SEMPER FI--1970 Dave
Old Apr 14, 2005 | 01:46 PM
bobs77vet's Avatar
bobs77vet
yikes that sounds painful....
To Fuel Leak somewhere on Fuel Pump
