BUshings...urethane or rubber?
I'll let you know how it worked out in about 30 years.
Only rubber bushings left are on the rear trailing arm pivots.
If you grease the bushings well during assembly, they should
not squeak at all - for a long time.
I used the VanSteel deluxe front kit - bought when they had a group purchase.
I am pleased with everything but the tie rod end boots. I cleaned and
used the ones that were already on there.
Urethane lasts a lot longer and is quite a bit harder. That makes it excellent in all the pivoting suspension items, like trailing arms, struts, A-arms, etc... It holds the suspension geometry better in use and over time. I only see two disadvantages with it. One is that it can squeak. With proper lube at install it may be a few years though, possibly longer than rubber lasts. The second is the flip side of it being hard, it can transmit more vibration in some uses.
Rubber is stock if originality is of interest. Rubber is softer and in some mount uses can help isolate minor vibration. Also rubber resto parts from GM usually fit pretty good. But rubber deteriorates a lot faster and when it does there's lots of room for the parts to slop around. I had TA bushings that were not much more than a table spoon of black dust.
I use urethane on all pivoting suspension elements and everywhere unless I think that vibration transmission is an issue. Personally I used rubber on the rear diff support to frame (80-82) and trans mount and I'll probably use it on the body mounts when I get to that.
Rubber has no sliding motion, it's all twisting, urethane slides around so it could wear and get sloppy.
Another issue with sliding contact is it can cause bind in the suspension. I kinda whish I stayed with rubber. I see no great advantage to urethane.
With poly, there's always the chance they'll last longer than me!
If oil soaked and exposed to header heat ... perhaps much less time to fall apart.
Like I said - call me in 30 years and we will know about poly.
Good to hear Norval has been running his for 10 years now.
I'm sure his suspension has been exercised well.
I hope I live long enough to see my boys change them again.
That's assuming I'm too old to wanna do it myself - again.
I'll say this: what is in new cars today?
I just did my wife's Tahoe front brakes ... looks like lots of poly, but
I could be wrong. I'll have to poke around some more to see for sure.
... fairly confident that it is still stock ... bought it 5 years old.
