Windshield - DIY Installation
Old Apr 15, 2005 | 02:43 PM
pws69's Avatar
pws69
Default Windshield - DIY Installation Guide
Well, as I stated in a previous message, I took pictures during the install - but never made them available. I started feeling guilty (no feeking idea why!!) so......
I put this together for all YOU brave folks who want to give it a shot!
http://www.speakeasy.org/~pws/Corvette.htm
It's really not a bad job at all!
Good luck.
Paul
Old Apr 15, 2005 | 02:53 PM
Vette Gator's Avatar
Vette Gator
Paul,
Thanks for an awesomely documented project! You've given me the courage to tackle this job myself when I get to this point. Having the sequence of pictures will really help. Did you remove the old windshield yourself in one piece or was it already broken?
Old Apr 15, 2005 | 02:59 PM
pws69's Avatar
pws69
Originally Posted by Vette Gator
Paul,
You are very welcome!
It was already out when I bought the car - which was a basket case that had been started but then sat, untouched, for over 10 years. I haven't heard of many success stories removing them in one piece. New glass is cheap enough to not even try!
Old Apr 15, 2005 | 04:01 PM
NHvette's Avatar
NHvette
Cool ... I just might do this ... or at least find all the parts so the glass dude can do it right.
Now, I look at your avatar and all I see is a new windshield.
Thanks Paul
Old Apr 15, 2005 | 04:27 PM
robertmc48's Avatar
robertmc48
Veteran: Marine Corps
Excellent post.. !!!!! Thanks a lot
Old Apr 15, 2005 | 04:35 PM
brooksman9's Avatar
brooksman9
St. Jude Contributor
Great work. Very informative.
Old Apr 15, 2005 | 08:12 PM
pws69's Avatar
pws69
Thanks Paul
You're welcome - but you're still a tough act to follow!!
I'm sure you could do it...
Old Apr 15, 2005 | 08:32 PM
Sharky Guam's Avatar
Sharky Guam
Nice job! Thanks for the installation instructions.....
Old Apr 15, 2005 | 08:50 PM
kdf1986's Avatar
kdf1986
Thank you for the well documented procedure and photos.
I have a cracked windshield on my 72, and have to decide whether to take it to a shop, or try to do this myself.
kdf
Old Apr 15, 2005 | 09:05 PM
DonBecker's Avatar
DonBecker
I just took my windshield out on my 76...let me know if I need to post how I did it again...it was easy IMO, I did it by myself and I'm a 'smaller' guy (weigh about 125-130).
Just make sure you have some styrofoam to put it on before you lift it out!
Old Apr 15, 2005 | 09:15 PM
DonBecker's Avatar
DonBecker
pws69 thanks for the great guide!
BTW, can you suggest sources for some of that stuff (rubber blocks, etc...)
Thanks again!
Old Apr 15, 2005 | 10:01 PM
GDaina's Avatar
GDaina
You used a tape instead of butyl that comes in a tube?
Old Apr 18, 2005 | 08:35 AM
pws69's Avatar
pws69
Yes, I used the 3/8 tape (actually, I'd call it more of a rope) because it provides some "support". This helps a GREAT deal with the windshield depth. If you use just the butyl in the tube, the windshield can (and does) "sink" into it. This is why you will sometimes see multiple sets of holes in the s/s molding - the "extra" set of holes is put there to make up for improper glass depth.
Old Apr 18, 2005 | 08:45 AM
pws69's Avatar
pws69
Thanks again!
You're welcome!
I got the rubber spacers and butyl tape from a friend who had them around. I would start at NAPA - I believe they have most of it. Auto body supply would be my next stop (or first if it is more convenient).
Old Apr 18, 2005 | 10:34 AM
NHvette's Avatar
NHvette
Originally Posted by pws69
You're welcome!
Oh yeah - that's right. I bought a spool of butyl tape for sealing my
firewall to birdcage. It came with rubber spacer blocks ... almost forgot.
Readily available at better auto supply stores.
To Windshield - DIY Installation
