joe73vette's problem?
Apr 16, 2005 | 09:27 PM
Apr 16, 2005 | 09:50 PM
check valve adjustment? If those puppies are a little too tight they won't shut all the way and cause a missfire.
Apr 16, 2005 | 10:14 PM
Don't throw any more parts at it (7mm wires???). Check the valves first.
Apr 17, 2005 | 12:20 AM
Quote:
sorry...they are 8mm. It ended up being the wiring as far as I can tell...no more missing
on wood
Apr 17, 2005 | 12:21 AM
You might as well pull the valve covers and find the valve with the wiped cam lobe ,start with the exhaust side.
Apr 17, 2005 | 12:26 AM
Quote:
Apr 17, 2005 | 05:04 AM
Apr 17, 2005 | 09:13 AM
Quote:
Originally Posted by Jclgodale3
It is possible.
My orginal L48 did the same thing.
Two bad cam lobes.
I hope that's not the case with his motor.
Apr 17, 2005 | 09:40 AM
on wood
Hey folks, he said it was OK now
Apr 17, 2005 | 11:03 AM
thanks page
