Installing drain plug in differential
Old Apr 16, 2005 | 09:54 PM
Engage's Avatar
Engage
Default Installing drain plug in differential
Has anyone drilled into and installed a drain plug on an 81 aluminum
differential or would that weaken the casing too much?
Barry
Old Apr 17, 2005 | 12:49 AM
flynhi's Avatar
flynhi
My ace mechanic (who builds Open Road Race cars) recommends against this. In normal use, diff fluid seldom needs replacing. A leaking drain plug can waste your diff very quickly.
Old Apr 17, 2005 | 01:10 AM
MIKER's Avatar
MIKER
Barry
When I performed the rebuild/gear swap on my '80, I installed a 1/4-20 NPT brass drain plug. It hasn't leaked a drop. I have no idea whether or not the installation of this drain plug weakened the casing.
Old Apr 17, 2005 | 09:19 AM
Engage's Avatar
Engage
Thanks guys... anyone else have this done?
Old Apr 17, 2005 | 09:28 AM
GTR1999's Avatar
GTR1999
I do them all the time in the earlier iron housing without a problem. what I did on Muncie aluminum cases is to drill and tap a 1/4 npt hole and use a 1/4 x 1/8 npt brass bushing with a 1/4 npt plug. The bushing is sealed into the aluminum and you don't wear the threads out because you use the 1/4 plug for the drain. I first did this 25 years ago and there have been no problems with it. I wouldn't drill into the housing though until it was accessible to clean out the chips.
Gary
Old Apr 17, 2005 | 09:47 AM
Engage's Avatar
Engage
I was thinking of drilling and tapping a 1/2 inch magnetic plug into it while the differential was in the car. The 81 is a real pita to get at.
Barry
Old Apr 17, 2005 | 10:03 AM
ram82fire's Avatar
ram82fire
I have installed a drain plug in my 82 alloy housing ,,,,,,,, no leaks or problems . Send me an email and will send pics & info if needed.
Geo
Old Apr 17, 2005 | 10:09 AM
Mike Mercury's Avatar
Mike Mercury
In the Feb 2003 Corvette Fever magazine there was an indepth article detailing how to add a diff drain plug.
Old Apr 17, 2005 | 10:59 AM
Engage's Avatar
Engage
Mike,
Could you post or email me a copy of it?
Thank you.... b.bugera@shaw.ca
Old Apr 17, 2005 | 11:01 AM
spikezz4's Avatar
spikezz4
Default Diff Drain Plug
The shop I'm with puts together a kit for exactly that purpose for C3's and C4's. When the daily maintenance shop was running, practically everything that came in went out with a drain plug installed, if the owner planned on being a regular. If you can not find the kit in one of the catalogs, email me and I'll see if they can send a kit out to you.
Spike
spikels6@thevillages.net
Old Apr 17, 2005 | 12:01 PM
Engage's Avatar
Engage
Thank you Spike
Old Apr 17, 2005 | 01:22 PM
Mike Mercury
Barry, I looked on their web site but couldn't find it online. I do have copies from the magazine though. I'll see about scanning the pages... or possibly snail-mail copies to you.
Old Apr 17, 2005 | 01:41 PM
Mike Mercury
here are the scans from the Corvette Fever article:
http://tim.yvonne.pro.home.att.net/m.../C3-diff-1.jpg
http://tim.yvonne.pro.home.att.net/m.../C3-diff-2.jpg
http://tim.yvonne.pro.home.att.net/m.../C3-diff-3.jpg
and here is a link to a person that sells a kit:
http://www.corvetteclinicinc.com/c3solutions.html
To Installing drain plug in differential
