Need Help! Almost lost a wheel!
Old Apr 18, 2005 | 09:11 AM
VettePower's Avatar
VettePower
Default Need Help! Almost lost a wheel!
Coming off the freeway, and slowing down, I noticed a clicking sound coming from my drivers side front wheel. I thought maybe I picked up a stone. I kept driving slow, about 35, and the noise kept getting worse. I finallt pulled over, and to my shock, 2 of my studs had sheered off, and the other 3 lugs were hanging on by threads. I managed to tighten the remaing 3 lugs and limped home. I can only think what would have happened if the wheel came off on the freeway, when I was going an average of 75.
This is a good time to warn everyone, especially with aluminum wheels, to check your lugs today.
Now for the help. What is the procedure to replace the sheared off studs on the front ????????
Old Apr 18, 2005 | 09:38 AM
kona's Avatar
kona
I've never had to replace mine but if I had to take a guess I bet they are pressed in and will need to be pressed out. Only a guess.
Kona
Old Apr 18, 2005 | 11:16 AM
VettePower's Avatar
VettePower
What is the dissasembly process to get to them???
Old Apr 18, 2005 | 02:49 PM
LABulldog's Avatar
LABulldog
Been there! Done That!!
Had a tire come off while driving through campus back in the days on my '71 Cutlass. Sheared off 4 of the five lugs. Don't know if the procedure is the same on a Vette but I used a punch and a bfh and drove the remaining lugs out from the front side of the hub. Put new lugs in from the back and then tightened them down with a lug nut. It pulled the lug into the hub. Never had a problem again. Good Luck!
Jay
Old Apr 18, 2005 | 06:18 PM
litevette's Avatar
litevette
Remove the wheel.
Remove the brake caliper with two bolts from behind.
Remove bearing dust cap. Tap a narrow flat headed screw driver behind the flanged portion to get it off.
Remove cotter pin and castle nut.
Pull off the rotor.
Press or hammer out old studs.
Reverse the process.
When you tighten the castle nut while putting it back on, just tighten it slightly. You should be able to spin the rotor , but not have play if you pull it from top to bottom or side to side.
Now would be a good time to check out the bearings. Make sure you repack them with grease. I wasn't as lucky as you, my wheel did come off!
Old Apr 19, 2005 | 08:38 AM
ICEMAN59's Avatar
ICEMAN59
Originally Posted by litevette
Remove the wheel.
Pull off the rotor.
Old Apr 19, 2005 | 09:18 AM
VettePower's Avatar
VettePower
Remove the wheel.
Pull off the rotor.
Litevette - Thank you very much! All done thanks to your instructions. From now on, I check my lugs once a month!!!!
Old Apr 19, 2005 | 03:02 PM
litevette's Avatar
litevette
No problemo! I now check mine every time I drive it. I got a little more scared than you I geuss.
Old Apr 19, 2005 | 07:19 PM
82Vette'ster's Avatar
82Vette'ster
Originally Posted by VettePower
....what would have happened if the wheel came off on the freeway,.....
Been there...55 mph, scary. I didn't know it, but during the night someone had tried stealing my wheels. They must have gotten scared off after removing 3 lug nuts. I wondered what the vibration was and before I knew it the drivers front wheel exited through the fender with a bang. Hitting the brakes resulted in severe pull to the left, which put me into the gravel shoulder, and a quick trip down the embankment. I was lucky I didn't hit anything big, just a few bushes.
Fender was trash. A guy brought my wheel back, he said it continued down the road quite a ways. 3 of the studs were a little tattered from the wheel coming off, the other two studs (next to each other) were gone. When I finally got back to my apartment there was one lug nut was still on the ground, that's when I figured it out.
I don't live there any more, and still check my wheels fairly often.
Old Apr 20, 2005 | 11:16 AM
Willis's Avatar
Willis
Here's one for ya, we went to the 50th anniversary celebration in nashville back in '03. I had my 81, father in law had his 68 and his 72. The drive was 1500 miles each way. (SLC to Nashville) On the way back, we were just outside Cheyenne Wyoming when my sister in law (in the 72) comes off the offramp hearing a loud clunk. We stopped at the nearest parking lot, which happened to be where we ate dinner. We thought that the front wheel bearing had gone to pot, but when we jacked up the car, we noticed that all the lugnuts had come loose. This was after close to 3000 miles of staying tight. The wheels weren't even aluminum, they were the steel ralley wheels. Go figure.
To Need Help! Almost lost a wheel!
