Idler Arm removal
Old Apr 18, 2005 | 11:45 AM
conway62's Avatar
conway62
Default Idler Arm removal
Anyone try to remove the idler arm on a BB with headers? I got the steeroids kit from the group purchase but looks like i may choose not to install it. Too much work to remove the headers on the BB.
Old Apr 18, 2005 | 12:45 PM
superdad60's Avatar
superdad60
I did mine, but had the headers out
Amazing how much room those headers take up
my passenger side headers come out in 10 minutes
I got the re-useable copper gaskets so I can do them as needed
You should be able to do it without removing headers
After removing the 2 idler arm nuts the bolts push put through the fraome so it can drop straight down
Old Apr 18, 2005 | 12:53 PM
norvalwilhelm's Avatar
norvalwilhelm
Headers are not hard to remove on my bigblock but for the idler arm they don't need to come out. Just remove the bolts. Probably your bolts are from the inside out and no outside to inside. I actually taped the holes in the idler arm the next size bigger so I could just use short bolts through the frame bracket and directly into the idler arm with no nuts on the inside to touch the headers.
Old Apr 18, 2005 | 01:08 PM
Van Steel's Avatar
Van Steel
Premium Supporting Vendor
Don't give up. Have at it
Old Apr 18, 2005 | 01:12 PM
BSeery's Avatar
BSeery
From: Exiled to Richmond, VA - Finally sold my house in Murfreesboro, TN ?? Corner of "Bumf*&k and 'You've got a purdy mouth'."
CI 6-7-8 Veteran
CI-VIII Burnout Champ
St. Jude Donor '06-'10, '13
Wow, I thought this was a problem on a small block. I can only imagine this mess on a BB engine. On my 350, my headers are about 1/8" from touching the idler arm, at most.
Good luck and keep at it.
Old Apr 18, 2005 | 01:20 PM
norvalwilhelm
My big block headers fit alot better then most small block headers. There is no problem removing/installing. They just about fall into place from the top or bottom.
To Idler Arm removal
