Dies at idle
Old Apr 18, 2005 | 01:53 PM
Garys 68's Avatar
Garys 68
Default Dies at idle
68 small block, edelbrock rpm, holley vacuum secondary, choke removed, no egr. 34 total advance with lighter advance springs, ported vacuum advance.
Just replaced the intake and added 1" 4 hole plastic spacer. Carb is recent rebuild.
Had it running great til sunday. Still has great top end, but now idle (700rpm) rpm will slowly drop off til it dies. Difficult to restart, have to floor the throttle when cranking, it usually backfire through carb then. I can keep it running if I throttle it.
I haven't even checked anything yet.
Doesnt sound like fuel starvation (good top end).
Spark is ok.
Vacuum leak?
Other thoughts?
Gary
Old Apr 18, 2005 | 02:55 PM
BigBlockk's Avatar
BigBlockk
Back your idle mixture screws out a little bit. If this helps you may need to open up the idle restriction a little. What sort of cam does this motor have?
BigBlockk
Later.....
Old Apr 19, 2005 | 04:17 AM
TLChydraulics's Avatar
TLChydraulics
might very well be bad power valve in your holley.... especially if it ever back-fired.... pretty common prob and easy fix.
Good luck,
Loren
Old Apr 19, 2005 | 09:02 AM
Garys 68's Avatar
Garys 68
And the answer is....................
Vacuum leak at the base gasket, under the spacer.
Gary
To Dies at idle
