Anyone try these trickflow heads?
Old Apr 21, 2005 | 08:41 AM
page62's Avatar
page62
I previously checked the TFS website for pushrod info. Unfortunately, they do not list a pushrod for the roller tips. They only have info on a selection of full rollers. So you're on your own unless someone around here has first-hand experience. to I'd suggest getting a set of pushrods in the length generally recommended by TrickFlow (can't remember it off the top of my head). Either these or your original stock pushrods (as a backup) should work!
I wouldn't worry about the exhaust crossover too much. If you have a hot-air choke (like I do), it's quite useful. And with the EGR blocked, it doesn't do much harm.
Old Apr 21, 2005 | 09:32 AM
Eddie 70's Avatar
Eddie 70
Ci 6, 8 & 10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
If I remember correctly, IIRC, you will need longer pushrods. Be sure to ask when you are ordering. I will see if I can find the instructions that came with the heads. It has the pushrod legth listed but still check to make sure.
