Will the Fuse Panel come out?
Old Apr 20, 2005 | 06:06 PM
79vetter's Avatar
79vetter
Default Will the Fuse Panel come out?
I took off the 2 threaded bolts holding it down but can't seem to get it out much farther. Is there something else that is holding it down?
My goal is to be able to see the back of the panel...thanks
Old Apr 20, 2005 | 06:31 PM
markdtn's Avatar
markdtn
THe 2 engine side harnesses are holding it in place. REmove the nut between them below the brake booster and you should be able to move it a little more.
Old Apr 20, 2005 | 07:21 PM
NHvette's Avatar
NHvette
Remove the nut on the engine side and it will come right out.
Careful with the old wiring ... or you might be looking for new harnesses.
To Will the Fuse Panel come out?
