Displacement Question
Old Apr 21, 2005 | 01:53 PM
Master Ho's Avatar
Master Ho
Default Displacement Question
If a 350 CID is overbored .080, what's the new displacement, in cubic inches? TIA.
Master Ho
Old Apr 21, 2005 | 01:58 PM
bobs77vet's Avatar
bobs77vet
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
Master Ho
can they go that much?
Old Apr 21, 2005 | 02:07 PM
panchop's Avatar
panchop
364 CID
Old Apr 21, 2005 | 02:14 PM
Maymyvetteliveforevr's Avatar
I was always told that if you go 30 over, the cylinder walls start getting to thin and your prone to overheating. Enhancement may have to be made to the cooling system to compensate. If you looking for ways to increase your cubic inch displacement to gain horsepower........there are other ways to achieve that.
Old Apr 21, 2005 | 02:19 PM
stingry's Avatar
stingry
St. Jude Donor '05-'06
Master Ho
Heres the math:
PI = 3.14159265359
Its all about area x stroke. You make the area bigger but the stroke is the same unless you get a stroker crank.
SB 350 has 8 cylinders with a 3.48" Stroke with a 4" Bore
D= 4" = 2R
R = 2"
CI = 8 x Stroke x Area
= 8 x 3.48" x 2" x 2" x PI
= 349.85 CI
= 350 CI
With a 0.030" over you get a 4.030" Bore and hence:
R = 2.015"
CI = 8 x 3.48" x 2.015" x 2.015" x PI
= 355.11 CI
= 355CI
With a 0.060" over you get a 4.060" Bore and hence:
R = 2.030"
CI = 8 x 3.48" x 2.030" x 2.030" x PI
= 360.421 CI
= 360CI
With a 0.080" over you get a 4.080" Bore and hence:
R = 2.040"
CI = 8 x 3.48" x 2.040" x 2.040" x PI
= 363.9816CI
= 364CI :o
Now what happens if you stroke that 0.080 with a SB400 crank (3.75")
You get:
CI = 8 x 3.75" x 2.040" x 2.040" x PI
= 392.22 CI
= 392CI
Counting, Counting, Always Counting (sinister laugh) as cookie monster enters on stage right........
Old Apr 21, 2005 | 02:22 PM
Thanks for the lesson stingry, brought back memories of auto class in high school.
Old Apr 21, 2005 | 02:24 PM
stingry's Avatar
stingry
You are right..sort off. A SB aint a SB. Each block and casting was different. The bottom line is that if you need to bore bigger it needs to be sonic tested. You can bore out huge IF the material is there and IF the block has no defects. Production line bores weren't exactly in the same place so a bore may be off center and have say .1" of liner on one side but only 0.05" left on the other side.
Like you said though the more you cut out, the closer you get to the water jacket. I have seen books where that is filled with concrete (serious stuff there) so that the water jacket doesn't allow the block to flex.
Old Apr 21, 2005 | 04:12 PM
fast idle's Avatar
fast idle
engines cooled from only the heads are strictly a race engine.and strictly 1/4 mile.any further and BOOM!!!
Old Apr 21, 2005 | 04:24 PM
Fubba's Avatar
Fubba
.080 over I only thought you could go .060, because of getting so close to the jets and having overheating problems. I guess you learn something new every day huh
Old Apr 21, 2005 | 04:44 PM
Gordonm's Avatar
Gordonm
At .080 on a SB the walls are so thin they would not hold up at all. .060 is pushing it. If you are loking for extra cubes stroke it.
Old Apr 21, 2005 | 04:52 PM
SanDiegoPaul's Avatar
SanDiegoPaul
From: San Diego - Deep Within The State of CONFUSION!
And [U]bore it.
To Displacement Question
By Michael S. Palmer | 2026-06-03 09:39:05
