fuel restriction?
Old Apr 22, 2005 | 02:26 PM
robs70vette's Avatar
robs70vette
Default fuel restriction?
Boy have I got what may be a real newbie question. I've got a 350 with moderate work (bored .030, aluminum heads, Air gap intake, Lunati cam, Holey 650cfm carb). When I go to full throttle, the carb seems to bog down (that's just my observation, it may be completely off). Is it timing related, accelerator pump related or something else? Along that line, when I do get chugging, say cruising at 80 MPH, the car will start to buck as though it can't get enough gas...
Any clues?
Old Apr 22, 2005 | 03:43 PM
bobs77vet's Avatar
bobs77vet
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
Any clues?
you may have a fuel starvation problem caused by a clogged fuel filter or poorly performing fuel pump
Old Apr 22, 2005 | 03:53 PM
robs70vette
If it is a fuel starvation problem and I'm looking at a replacement, what are the pros and cons of converting to an electronic fuel pump.
Old Apr 22, 2005 | 08:14 PM
bobs77vet's Avatar
bobs77vet
I am not an electric fuel pump fan unless you put in an inertia kill switch in case you get in a crash....the old fuel pumps work very well
Old Apr 22, 2005 | 10:35 PM
wildman378's Avatar
wildman378
I had this same problem it would run fine until you got on it then stumble around was a clogged fuel filter shes runs perfect now!
Old Apr 23, 2005 | 08:45 AM
robs70vette
I have a glass sight on my filter (less than 500 miles). It shows no signs of dirt or contaminants. Could there be blockage in the rubber lines? If so, how can I check it.
Old Apr 23, 2005 | 09:55 AM
bobs77vet's Avatar
bobs77vet
disconnect the glass filter crank enginewith coil grounded and watch,measure and time the amount of fuel it spits out....then compare to specs...(.i'm making this number up ...1 gallon per minute...)
Old Apr 23, 2005 | 07:32 PM
w1ctc's Avatar
w1ctc
I had similar problem last year with my Holly. I had the bronze inlet filter in backwards.
To fuel restriction?
