I'm new to the forum and I love it. Just bought a super nice 70 Coupe with 66K original miles. The car has been repainted (original color), but appears all original and unrestored otherwise. (I'll have to figure out how to post pictures).
Anyway, I notice a really strong gas smell in my garage from the Vette. I noticed it was much worse when the tank was over half full. I do not smell it under the hood, but if I open the fuel lid (with the gas cap fully secured) I can really smell a strong gas odor. Once the tank goes under half full or a little less, the smell is much less noticable. I have ordered a new gas cap, and will try that, but I think it is probably something else since my gas cap seems to fit tightly.
If I top off and park on a slant (mostly notice this uphill) I get gas leaking out the back. I think there are some rubber hoses or ??? on the top of the tank that are very inaccessible that might need attention. Perhaps your situation is similar.
Any thoughts on what might be going on?
Thanks for your help.
You have a fuel vapor condenser on the upper leftof the tank that takes fuel vapors and condenses back into liquid. These plastic pieces were never meant to last 35 years and, as a result, many C3 owners suffer this problem. The band aid cure is to not fill your tank above the 3/4 level and always park on a level spot. Since there aren't any any repro units available you are pretty much SOL. Sorry. I suffer the same problem with my 72.
There was a previous post where I showed how I fixed mine with Marine-Tex epoxy (better gas resistance than other epoxies). Here is the repaired vent canister. No more gas smell in the garage. Joe
to get to it you have to drop the tank almost completely out and reach up on the drivers side of the tanks and unbolt it! It is a lot of fun, especially if you still have youy mufflers in back there!
Actually it is a fuel vapor separator system tied into the charcoal canister in the driver side behind the wheel well. The part shown is a check valve. When you fill your tank this valve closes to keep raw fuel from going down the lines and ending up in the canister. Once the fuel level starts to drop this valve is allowed to open by the falling fuel level. Then the carb will suck excess fuel vapors off the top of the tank, throuhg the canister and into the carb to be burned. Is was one of GM's first attemps at emission control. Hopfully this valve is good and all you have is dry rotted rubber lines from the valve to the hard lines on the frame. Also check the lines from the canister to the carb. Our older cars have a closed fuels system so you should not have avented fuel filler cap either. Hope this helps on how the system works. The smell could be comming for any part of this system. I had the smell and had two problems.......dry rotted rubber lines to the check valve and a small pin hole in my tank in the same area. I got a new tank and my check valve was good. These valve are a bear to find and cost you an arm an a leg for a used one. Good luck.
The charcoal cannister was removed from my car, but there appears to be a vented cap in place now (owner drilled a small hole in each side of the cap to provide venting?) He did, however, leave the check-valve, and it's operable. I just completed installation of a couple of weld-in bungs for larger fuel line, and to use the existing 3/8" as return. I replaced cap as well. Question: Should I abandon (block-off) the vent at the tank and go with a vented cap, or, leave it to vent through the check-valve and line to the front of the car? Thanks!
If the cannister is missing, see where the hose on the drivers side goes. If it's just dangling, there is no need for the check valve by the tank and you can cap the vent hose fitting at the tank and use the vented gas cap. Joe
