Header Height
Old Apr 22, 2005 | 11:39 PM
supermeggs's Avatar
supermeggs
8th Gear
Default Header Height
My dad and I are restoring a 68 vette, and we recently got a set of Headman Headers. (I am his daughter, posting becuase I'm more computer able, and because the vette will be mine when I drive next year) While he was looking at them, he realized that they may get damaged if I go over speed bumps or such. He called the store where we got them, and he said no one has ever complained about them being to low. Just to be safe though, we figured it would be better to post and ask. So, has anyone ever had a problem with Headman Headers hitting?
Old Apr 22, 2005 | 11:49 PM
74FLCONV's Avatar
74FLCONV
They'll be fine. Just be careful over speed-bumps and steep driveway cuts.
D. Ocean
Miami, FLA
Old Apr 23, 2005 | 12:57 AM
BSeery's Avatar
BSeery
From: Exiled to Richmond, VA - Finally sold my house in Murfreesboro, TN ?? Corner of "Bumf*&k and 'You've got a purdy mouth'."
CI 6-7-8 Veteran
CI-VIII Burnout Champ
St. Jude Donor '06-'10, '13
I have headmans on mine. They only hit on tall speed bumps, and my car is very low. I have the front end too low for most street driving.
Old Apr 23, 2005 | 07:13 AM
DRL502's Avatar
DRL502
how are you? do you have 3 or 4 inches of clearance?
Old Apr 23, 2005 | 07:15 AM
DRL502's Avatar
DRL502
how low are you? do you have 3 or 4 inches of clearance?
Old Apr 23, 2005 | 02:35 PM
spikezz4's Avatar
spikezz4
Default Headman Headers Height
I had them for 10 years, and I put a big dent in one side by hitting some wooden road trash that popped out from under the preceding vehicle. The Hooker Super Comps have much better clearance, which is what I later used.
Also, when changing the oil filter with the Hedman's, the filter must be tipped to clear the exhaust pipe coming back from the collector which causes spilling no matter how you do it. The Hookers have adequate clearance for the filter to come straight down and out.
Spike
Old Apr 23, 2005 | 03:45 PM
Shark Racer's Avatar
Shark Racer
I'm having not great luck with the Hedmans but I drive it EVERY day... my car is low, not as low as Bryan Seery's, but I have found quite a few speed bumps it doesn't like, one that actually had the metal SCREAMING as I drug along it. Boooooy, was that bad.
All said, I -mildly- scrape over bumps all the time.
-Steve
Old Apr 23, 2005 | 03:54 PM
Matt O's Avatar
Matt O
Why don't you stay with the cast iron exhaust manifolds and a 2 1/2" exhaust system. There a lot of corvettes aaround with the stock manifolds.
Old Apr 23, 2005 | 04:56 PM
BSeery's Avatar
BSeery
CI 6-7-8 Veteran
My front fender measures about 25" from the ground to the top of the inside fender lip. That is without my heavy *** in the car. My tires are 26" tall if that gives you any idea of how low the body is.
Old Apr 23, 2005 | 05:06 PM
Guru_4_hire's Avatar
Guru_4_hire
Cruise-In IV Veteran
Cruise-In V Veteran
I dented my oilpan more than my headers.
Old Apr 25, 2005 | 07:15 AM
supermeggs's Avatar
supermeggs
8th Gear
Thanks everybody for your help. My dad and I are now discussing which to go with, the Headdman or the Hookers.
To Header Height
