69 gear decision
Old Apr 23, 2005 | 10:06 AM
KJLive's Avatar
KJLive
Default 69 gear decision
I really appreciate all the help with my last question. (I am a new member). Another question about my 69 rear. If if switch out the 3:70 to 4:11 will I notice a big difference? My motor was built several years ago and a friend stated I need a lower rear to get more cam performance from my motor. Thanks in advance for the help!
Old Apr 23, 2005 | 10:08 AM
page62's Avatar
page62
Information, Please...
How do you drive the car? Ever get on the freeway? Or are you more interested in 1/4 mile times...?
Old Apr 23, 2005 | 10:12 AM
Van Steel's Avatar
Van Steel
Premium Supporting Vendor
Yes you will notice a big difference. If your more of a highway driver, you're probably going to get sick of the gear b/c your RPM's will be going through the roof. If your more of a stop light to stop light kind of guy than you'll love the 4:11's. You will NOT have to change you posi unit either. You just have to get a thick 4:11 gear.
Dan
Old Apr 23, 2005 | 10:14 AM
KJLive's Avatar
KJLive
I only drive the car a few hundred miles/year. I may drive to the Carlisle PA show which is about 40 miles from my home. (Not too much highway...mainly just fun cruising!)
Old Apr 23, 2005 | 05:24 PM
markdtn's Avatar
markdtn
IMHO 4.11 is a lot of gear. I would stay with the 3.7 particularly with a non-overdrive transmission. Unless all you ever do is drag race and you really don't care about street driving at all. 4.11 is going to be turning a lot of rpms all the time.
Old Apr 23, 2005 | 05:36 PM
joe73vette's Avatar
joe73vette
I had 4.11's in a street rod a while back. Even with tall 275/60 tires, it was a lot of gear. I think I would have been happier and maybe faster with 3.93's (in a ford 9"). With the 4.11's I could do burnouts through all 4 gears, but 1st gear was done in 20 feet . Highway cruising was also tedious, but not impossible. The guy who bought it went to many shows a couple of hundred miles away. If you have an automatic, with the converter's torque multiplying, I'd definitely stick with 3.73's or you'd never get traction. Joe
Old Apr 23, 2005 | 09:43 PM
A C's Avatar
A C
Cruise-In II Veteran
I have 3.70's, and even when I had a very big cam, I thought these gears were pretty steep for street driving. I would be in fourth gear on main drags with a 40 mph speed limit. You will shift a LOT with 4.11's on the street with a decent set of pipes (running at over 3000 RPM will get annoying). I think 3.55's are probably a good compromise set of gears...maybe even 3.36's. Unless you have a HUGE cam, 3.70 gears will not hurt your performance IMO.
To 69 gear decision
