Help - can you identify these brackets?
Old Apr 23, 2005 | 05:52 PM
DBM_NJ's Avatar
DBM_NJ
Default Help - can you identify these brackets?
I purchased my 1973 350ci vette this winter and finally getting around to working on it. I don't have the original build documentation and am not sure what was originally attached to the brackets shown in the picture. Any help would be appreciated.
Also - if I remove them, do I need to be concerned with bolt lengths or torque?
Old Apr 23, 2005 | 06:09 PM
JB's Avatar
JB
St. Jude Contributor
One on the passenger side is smog pump. Other is just the ring for lifting the motor out, I think.
JB
Old Apr 23, 2005 | 06:15 PM
joe73vette's Avatar
joe73vette
The top one is for the A.I.R. pump (emissions), the bottom is one of the factory lifting brackets when they installed the motor. I'd replace the bolts with shorter ones where the A.I.R bracket was, the intake manifold bolts are 1.25" long, need sealer, and torque to 20 ft-lbs. The water pump bolt also needs sealer, but I don't know how long it should be, measure yours and subtract the thickness of the bracket. I like leaving the lifting bracket, it keeps the factory look, but that's just my opinion. Don't throw out the A.I.R bracket, they are hard to find. Joe
Old Apr 23, 2005 | 06:16 PM
RHD '68 L89's Avatar
RHD '68 L89
Smog pump and lifting hook. there should be another hook diagonally oposite on the rear of the motor.
Old Apr 23, 2005 | 06:34 PM
DBM_NJ's Avatar
DBM_NJ
Thanks - do you know if California is the only state that required smog pumps in 1973? I am trying to research the car's history and that might be a good lead.
Old Apr 23, 2005 | 08:08 PM
redwingvette's Avatar
redwingvette
All 73's came with smog pumps.
Old Apr 23, 2005 | 08:15 PM
73jst4fun's Avatar
73jst4fun
Ditto here, don't throw anything out, and take a photo of everything...
To Help - can you identify these brackets?
