Slow power Locks
Old Apr 23, 2005 | 09:54 PM
toyvet1's Avatar
toyvet1
Default Slow power Locks
Replace the power door lock motors, cleaned and oiled all connections and the locks them self. Ground wire on pass door cleaned also. Drivers door works fine. any ideas why passenger door struggles to work . Im thinking power problem. Any ideas as how to check that.Its a 79 by the way.
Old Apr 23, 2005 | 10:02 PM
DonBecker's Avatar
DonBecker
measure the current/voltage at the drivers, then do it on the passenger's. That would lead you do what's different?
Old Apr 23, 2005 | 10:50 PM
Boofers's Avatar
Boofers
Mechanical problem with the door lock mechanism? Is the passenger side harder to move by hand?
When you say oiled all connections do you mean you put oil on the electrical connectors? If this is the case the oil could be causing a bad connection as oil is a really good insulator & does not conduct electricity.
Ya what Don says - if the passenger motor is getting less voltage it could be a wiring issue. Trace back until you find a component that has good voltage going in but less coming out...
Cool looking car btw!
Old Apr 23, 2005 | 10:55 PM
toyvet1's Avatar
toyvet1
No I didnt oil the electic connection just the lock rods and lock...
To Slow power Locks
