holley 4160 and pcv ?
Old Apr 24, 2005 | 02:26 PM
loUiSiAna van's Avatar
loUiSiAna van
Default holley 4160 and pcv ?
I just finished up a zz4, th400, and mallory distributor with mac adv. My ? is where to run my pcv valve, the carb has 3 ports. The power brake, the vacuum advance ,and a small full manifold vacuum port. I also have the intake fitting with 2 ports.
Old Apr 24, 2005 | 02:45 PM
Paul L's Avatar
Paul L
This might give you some ideas. Transmission modulator valve and PB vacuum come off the fitting at the back of the intake. Large rubber hose in middle of pic is PCV and the smaller hose is vacuum advance.
Old Apr 24, 2005 | 02:57 PM
loUiSiAna van
I have a 74, i need vacuum to work the lights also. will the brake and transmission together hurt the transmission when braking.
To holley 4160 and pcv ?
