Distributor ground?
Old Apr 24, 2005 | 03:58 PM
jerryjfunk's Avatar
jerryjfunk
Default Distributor ground?
Is a HEI distributor supposed to have a direct ground to the engine? If so, where is it supposed to connect?
Thanks!
Jerry
Old Apr 24, 2005 | 04:38 PM
silver74vette's Avatar
silver74vette
The ground for the HEI (I am talking non-computer controlled) is the mount to the intake manifold. The cap connections should be: The plug from the side of the distributor, 12V from the ignition and the tach wire. There is no individual wire for a ground.
Hope this helps,
Old Apr 24, 2005 | 04:46 PM
comp's Avatar
comp
do you have a ground strap to the frame ???
Old Apr 26, 2005 | 10:42 AM
jerryjfunk's Avatar
jerryjfunk
silver74vette: Ok, thank you. I just thought it was weird because of the gasket between the distributor and the intake.
comp: Yep, I have all the ground straps in place!
To Distributor ground?
