Gasket sealing questions....
Old Apr 24, 2005 | 09:29 PM
c3vettelover's Avatar
c3vettelover
Default Gasket sealing questions....
What is the "best" way to seal engine gaskets to prevent leaks?
Old Apr 24, 2005 | 09:43 PM
62fuelie's Avatar
62fuelie
This is gonna depend on which gaskets you're refering to. For the sheet metal parts, ie, pan, timing cover, valve covers, etc. I like the cork gaskets. I glue the gasket to the sheet metal part with weatherstrip adhesive and nothing on the block side. The exception is the valve cover gaskets. I put a thin film of grease on the side that goes tothe head. This seems to help keep them from sticking if i have to remove for maintenance.
Many recommend silicone. I don't like silicone because i've taken apart to many engines with silicone in places where it shouldn't be. If you must, use silicone on the front and rear of the intake manifold instead of the neopreme gaskets supplied. Be sure to keep the silicone out of the lifter valley if you do this.
Everyone has a favorite method, choose your poision and take your chances. The real key is clean surfaces and properly positioned gaskets.
Old Apr 25, 2005 | 09:34 AM
GasketDude's Avatar
GasketDude
Proper torque is the most important. Next comes the sealing surface finish. Such as corrosion on Aluminum manifolds or rusty Cast Iron Water Pumps. And last is the condition of the theads in holes and on fasteners. All of these insure a proper seal and provide the proper load on the joint to keep it from leaking.
When selecting a gasket, don't go with the cheapest. Spend a little extra and get the right type. Such as the Fel-Pro Perma-Toque line. These have been proven to solve problem applications (Chevy V/C's). Also the one piece Oil Pan gaskets for the older Chevys have save many driveways accross America. There are some other quality gasket manufactures out there, just spead that wallet a little more and you be better of.
And finally, don't get carried away with RTV or Copper type sealers. The gaskets are designed to be used without sealers,(unless noted) and as long as everthing else is in good shape they will seal correctly.
Have fun,
Later.
To Gasket sealing questions....
