I just did mine...the "special tool" I used was a .014 feeler gauge to push the lip of the seal into the bore as I apply slight pressure, I also use a flat body shop hammer to start the dust boot and finish it off with a smaller hammer and a brass drift punch.....when you disassemble, the "stainless sleeve" should be easy to recognize as it`s shiny compared to the caliper cast iron, there will be a line at the top and a ring down near the bottom of the bore separating the two surfaces......I would also buy a seal kit from VBP or lonestar (NOT Autozone or Pimp Boys, I had trouble with AZ seals), or even NAPA......And do ALL 4 while your at it..
.....redvetracr
I bought last year a '67-'82 Corvette Caliper Seal Installer which is just kinda like a plastic pipe which is the same diameter as the seal. It also has a lip on it so it stays centered in the seal as you lightly "tap" the seal into place. Most people install their seals without this tool, but I like it myself.
On the front calipers, I use a 1 1/2" PVC pipe coupler to tap in the dust seal. Available at any hardware store. I use a socket on the smaller rears, not sure which size it was, tho.
Careful prying out the old dust seal, don't score the stainless sleave.
Mike
Went out and checked the socket size to press the rear dust seals in, 1 1/4". Also found that I had purchased a PVC coupling to do the rears next time. 1" coupling.
Thanks for all the responses.........still just one question remains: Regular seal kit or one for Stainless Sleeved caliper??? Same???
Almost forgot: Good idea to lighly coat the seals and bores with some brake fluid before assembly (pressing seals) ????
Thanks abunch
Same seals for sleaved or non sleaved. And yes, lightly coat the lipseals and bores with brake fluid. I believe there in an assembly lube but the fluid is OK. Don't put any on the dust seal.
Also, don't use paint thinner or gasoline to clean up the parts. Residue can eventually damage the new rubber parts. Use brake parts cleaner or denatured alcohol.
Mike
SAME seals!! Raybestos makes an assembly lube it`s about $7.00 and will last you forever....although I am on my third bottle.
....redvetracr
I purchased new SS calibers about 5 years ago and had them opertional for a couple of years, then let it sit for 2 years as I prep the body for painting. Now the fronts leak like there's a wide-open leak after 18 months of non-use. Anyone else seen this type of failure, and what to do about it?????
