Battery disconnect
Old Apr 25, 2005 | 08:47 AM
Steve's74's Avatar
Steve's74
Default Battery disconnect
I know this has been discussed before, and that the search function is improved, but I can't find it. I'm looking for a battery disconnect for our side terminal batterys. Is anyone using one of these and where did you find it? Thanks in advance.
Steve
Old Apr 25, 2005 | 09:10 AM
bb69's Avatar
bb69
I am using a Moroso battery disconnect switch. It is a large switch, instead of the type that use a green ****. The benefit is the disconnection/connection is positive. The switch has two large lugs on the back. I was already replacing my battery cables, so this was easy. I recommend these over the type that use the know because those can be intermittent, leading to dead batteries, and in severe cases, fires.
Ken
Old Apr 25, 2005 | 09:16 AM
Paul L's Avatar
Paul L
I picked up this one at JC Whitney.
Old Apr 25, 2005 | 09:19 AM
bobs77vet's Avatar
bobs77vet
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
www.eastwood.com
part number 25009 19.99
Old Apr 25, 2005 | 10:50 AM
Steve's74's Avatar
Steve's74
Bingo Paul! That's the one I'm looking for, a knife blade switch. Found the part number. Thanks a bunch.
Steve
To Battery disconnect
