Gas Smell
Old Apr 25, 2005 | 10:08 PM
Adam Wartell's Avatar
Adam Wartell
Default Gas Smell
After I have been driving around for a while in my 79, when I get home, the car sits in the garage for about 10 minutes or less and, I smell gas REALLY strong. The smell will linger in the garage for about 6 or 8 hours after shutting off the car.
I do not see any gas leaks on the ground, nor do I see any leaks near the carb.
Any ideas what is going on? One suggestion I got was about some sort of emissions canister, under normal operation, could be causing it. But I never used to smell it before.
Any help would be great!
Thanks!
Old Apr 25, 2005 | 10:22 PM
desi's Avatar
desi
Is it after you fill the gas tank? I was over filling mine the first year I had the car. In that case, it would leak a little causing the smell. There is small drain on the driver side, under the master cylinder. I only fill about 7/8 of the tank. Hope that helps...
Sixminuteabs's Avatar
Sixminuteabs
If Qjet...maybe leaking fuel bowls after you shut off engine...is car hard to start after sitting awhile?
Or maybe float too high...is gasket, not carb to manifold but upper one near air cleaner....is it saturated with fuel? Does it look wet?
6
Old Apr 26, 2005 | 12:37 AM
Paul Borowski's Avatar
Paul Borowski
Cruise-In VI Veteran
St. Jude Donor '08-'09-'10-'11-'12
If your car has the original rubber lines back at the tank, I'd bet it's one of those. A few years ago, my Silver '75 coupe had such a small leak in the rubber supply hose where it hooks to the main metal fuel line that the fuel would evaporate BEFORE it would accumulate and make a puddle on the ground. I could always smell the leak, could never find it until one day I backed the car on ramps and saw the "staining" on the aged rubber line above the right muffler from the fuel coming out of it. The rubber line had just aged enough where gas was seeping out of a crack that went all the way through.
Old Apr 26, 2005 | 01:14 AM
The_Dude's Avatar
The_Dude
St. Jude Donor '11, '16-'17
I had a very similiar experience. The gas would drip onto the hot muffler and instantly evaporate, so there never was a puddle. One day I just happened to see it dripping.
Old Apr 27, 2005 | 12:13 PM
Adam Wartell
You said you could "always smell" it. After my car has been sitting in the garage, unrun, for 24 hours, the smell is gone.
Does that help narrow down where it is coming from?
I'll have to get under the hood/car this weekend and check out what you guys are suggesting.
Old Apr 27, 2005 | 12:35 PM
JBR's Avatar
JBR
The wifes 78 had a gas smell after you shut it off, yet no puddle was found. Along the passenger side frame I found that the return line had a very small pin hole (rust) in it. I replaced that section of line and the leak was gone. Once the pressure in the line would be gone, the pin hole would stop leaking. Follow your lines from the carb to the tank I'm sure you will find something. Next do you still have the spare tire carrier on the car? If so remove it and the spare and check the tank bottom.
Old Apr 27, 2005 | 12:44 PM
Adam Wartell
Another good suggestion!
I have recently removed the spare tire to check the tank, but the once I pulled down the tire, I realized that the tire carrier also had a top to it, that was still blocking my access to the tank. I guess I'd have to take the carrier completely off, huh?
Who lives in the Philadelphia area and has lift they want to let me use?
Thanks!
Old Apr 27, 2005 | 12:56 PM
Paul L's Avatar
Paul L
Check the rubber S-hoses at the fuel pump for end rot.
Old Apr 27, 2005 | 01:05 PM
din1780's Avatar
din1780
7th Gear
If you don't find any leaks the problem is probably caused by your charcoal canister (that was my problem on a 79)
Old Apr 27, 2005 | 03:33 PM
carl a's Avatar
carl a
does your year have one of these attached to the drivers side of the tank?its a fuel vapor seperator valve that leads to the charcoal cannaster if so,,check underneath it after filling it up,,,usually drips on muffler or pipes,,,take it out if leaking ( 2-- 5/16 hex screws)and re-glue the top(glue breaks down after 25 yrs) ez to repair and there no longer available-------------
Old Apr 27, 2005 | 09:09 PM
Adam Wartell
Sounds like I'm going to be crawling under my Vette this weekend. UGH! I really need a lift!
Thanks for the tips, guys! If anyone has more, please let me know!
Old Apr 27, 2005 | 10:13 PM
bobs77vet's Avatar
bobs77vet
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
Thanks!
yeah buts it really easy to take the top off...the pain is the two funny long hanging bolts that the tub is held up with..
To Gas Smell
