Cam and heads match question
Old Apr 26, 2005 | 06:31 AM
jannu's Avatar
jannu
Default Cam and heads match question
Considering replacing stock L48 heads with SUM-152123 Summit/Dart iron heads.
Should I replace my brand new, but mild Edelbrock #2102 cam with more aggressive cam or could I expect reasonable torque and horsepower gains using current cam? ( 204 int./214 exh. duration @0.050" lift, 0.420 int./0,442 exh. lift, 112 degrees lobe separation)
The car is basically stock 78 L48 with TH350, stock converter, Edelbrock Performer intake, Holley 4165 - 650cfm double pumper carb and 1 5/8" Hedman headers.
Old Apr 26, 2005 | 08:10 AM
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
I would keep the cam and go with 1.6 rockers and your lift goes up by about .030". Make sure the pushrods don't rub anything the 1.6 RR.Also put on a steel shim head gasket to bump up the compression
Old Apr 26, 2005 | 08:44 AM
page62's Avatar
page62
Those heads have slots that are designed to handle 1.6 rockers without pushrod interference. But be sure to check anyway.
BTW: The pushrod slots are also machined to act as guides for the pushrods. Do not use guideplates -- they could actually interfere and cause binding! (I checked with Dart, and this is what they told me...)
Old Apr 26, 2005 | 08:48 AM
isosceles's Avatar
isosceles
do you already have a decent intake manifold and headers? If not, those will then be the bottlenecks restricting flow.
Old Apr 26, 2005 | 08:52 AM
Pauld's Avatar
Pauld
I have just bought that cam from Summit aswell, I went with aluminium heads from Edelbrock to match. I didn't want a too aggresive cam just a good mild cam. Anything is better than the stock L81 cam
Old Apr 26, 2005 | 09:02 AM
page62's Avatar
page62
That IS a mild cam, especially considering the L82 cam is 222/222, with .450/.460 lift.
What are the specs of the L81 cam?
Old Apr 26, 2005 | 12:09 PM
Pauld's Avatar
Pauld
I know the edlebrock is quite a mild cam and I know the L81 cam is a very poor performer, I did have the specs for the L81 cam somewhere but can't find them now
Old Apr 26, 2005 | 06:06 PM
painterman52's Avatar
painterman52
I have that cam & those heads. I used the 1.6 roller rockers. I also have headers into 2.5" true duals with magnaflow mufflers. I`ve got the performer intake & 600 cfm edelbrock carb. It`s got way more power than stock. I just did the heads, rockers, & exhaust 2 weeks ago. What a difference.
Old Apr 27, 2005 | 05:59 AM
jannu's Avatar
jannu
L81 and L48 both use GM#3896929 cam: 195/202, with .390/.410 lift
Old Apr 27, 2005 | 06:36 AM
jannu's Avatar
jannu
Thanks guys!
I will keep the cam and go with 1.6 ratio rockers.
Is this set of Summit rockers SUM-141507 acceptable?
Can I still go with stock length pushrods?
Old Apr 27, 2005 | 07:00 AM
painterman52
I used stock length pushrods. For $60 more you can get roller rockers instead of roller tips.
To Cam and heads match question
