I never used the word 'stupid' and George in the same sentence. You are reading way, way too much into it. Doing that would get me banned for life. Can they do that since I just signed up for a lifetime membership?
As a matter of fact...they CAN. You shoulda read the fine print
I was just funnin ya. NOBODY has the brass nads to call George stoopid.
Autozone has and will let you "borrow" the priming tool.......for those that don't know how it works...pay for the tool, use it, bring it back and they will credit your account.
Simple. Saves on buying all sorts of stuff you only need one.
The little Moroso primer will prime the oil pump and the main feed line, but won't fill all the lifters. You need the part of the distributor that seals at the bottom to get oil to the other side. It took about 5-10 minutes before oil came out all 16 rocker arms. I was able to get 40 psi with my 1/2" drill, too.
I've seen the good primers in catalogs, probably about $40. I paid $10 for a junk HEI, and it took half an hour to get it apart and make a tool I'll have forever, if I don't lend this one out.
Joe
PS, if you want a good price, visit the salvage yard don't just call.
