Pwr Window Motor Question
Old Apr 27, 2005 | 12:50 PM
Gage's Avatar
Gage
Default Pwr Window Motor Question
Pwr window works went it wants to. Thought it might be the switch, but noticed that the amps are drawn down when I hit the switch, and a slight click sound coming from motor, but no go. I took it out and hooked it up to shop batt and it works fine both directions, put it back in car, works fine, then today, doesn't work. I'm assuming if it was a grounding problem that their would be no amp draw or sound coming from the motor. Time to replace the motor?
Old May 5, 2005 | 12:15 PM
Gage's Avatar
Gage
ttt
Old May 5, 2005 | 12:35 PM
Marv's Avatar
Marv
Have you checked the relay for proper operation? Good luck.
Old May 5, 2005 | 01:18 PM
82XFire's Avatar
82XFire
Tell us more about this relay, my passenger side drops like a rock despite all new components in the door and new switches.
Hmmmm........
Old May 5, 2005 | 03:49 PM
Gage's Avatar
Gage
Yes, When I probe harness that plugs into the motor, it lights up everytime, up or down terminals. The motor is getting power.
Old May 5, 2005 | 10:29 PM
jbs75's Avatar
jbs75
I had problems with my pwr windows too; ended up replacing the plastic guide wheels, cleaning and lubing everything else. The old grease will harden up on you and cause a lot of drag. In my case(75), all the current goes through the switch in the console; and I had to clean those contacts too. I think I may have some missing, or broken ground wires too; but it works pretty good now.
Jim
Old May 6, 2005 | 07:32 AM
78pacer's Avatar
78pacer
Your window motor is toast.
Mike
Old May 6, 2005 | 09:21 AM
jbs75's Avatar
jbs75
I forgot probably the biggest drag on window operation. Replace the track inserts that the window rides in at the front and back. When you "looze the fuzz" it rattles and drags more. I would do this and the other things regardless of whether the motor is bad or not. Alittle silicone spray in the tracks wouldn't hurt either.
Jim
Old May 6, 2005 | 09:48 AM
Toms82's Avatar
Toms82
Default Power Window Motor
Hi,
My left window was doing the same thing. It is much better now that I lubed the tracks.
Good luck,
Tom
To Pwr Window Motor Question
