As the title implies I need some info on what size throttle cable I need.
The stock cable is too long for use with my Demon carb. It is at a bad angle and it needs to be replaced.
I want to get one of the Lokar cables, but am unsure as to what length to order? My throttle cable bracket has the square hole and the carb has the small ball-stud.
