Heater Fan
Old May 8, 2005 | 11:44 AM
Tom Johnson's Avatar
Tom Johnson
Thanks guys for all the great help. I finally located the blower motor. That baby is really hidden. Looks like I can get at it from the top and through the side vent panel which is removable. I am going to hook power directly to it just to make sure its the blower motor.
Old May 8, 2005 | 05:00 PM
flynhi's Avatar
flynhi
Before going thru the pain and misery of removing the blower motor, check the positive and ground. A poor connection on either could be your problem.
You may also have an evap box full of leaves and other accumulated crud. Duct tape a 3/4 hose to the end of your shop vac and snake it down the fresh air intake in the passenger side cowling. Gently move it around to remove the stuff that is blocking your AC evap core.
