79 dash ground
Old Apr 28, 2005 | 10:13 PM
toyvet1's Avatar
toyvet1
Default 79 dash ground
I am having problem with the tail/stop/gauge lights out. I can't find the ground for the dash, The shop manaul says near drivers hinge above courtisy lamp. I cant find it, does anyone have a better location discription.......
Old Apr 29, 2005 | 03:02 AM
c3 in hawaii's Avatar
c3 in hawaii
I hope someone can answer this,I am having the similar problem with my '78.. also looked for the ground and was unable to find it...I am about to pull my gauges and dash out this weekend, will let you know if I find it..
Old Apr 29, 2005 | 06:45 AM
toyvet1's Avatar
toyvet1
Fuses are good so i am starting to look at the headlight switch,all but the brake lite go through it. I'll let you know what I find..
Old Apr 29, 2005 | 07:43 AM
igo4vols's Avatar
igo4vols
On my 77 it is near the drivers door hinge behind the kick panel.
Old Apr 29, 2005 | 07:48 AM
79vetter's Avatar
79vetter
It is on the left kick panel just to the left of the grill . I will try to take a picture later and post...
Old Apr 29, 2005 | 11:55 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
It's not supposed to be visible from the occupant area.
Old Apr 29, 2005 | 12:23 PM
Ak. Mal's Avatar
Ak. Mal
From: Kansas City, MO ...I'd like to go fishing and catch a fishstick. That'd be convenient. - Mitch Hedberg
I suffer from a similar problem. However, I have located my problem area. It is where the white wire from the tail lights enters into the harmonica connector at the steering column. A slight wiggle and they start working again.
If the ground isn't your problem, I suggest you look at the wiring in and out of the harmonica connector. With the exception of the headlights, all of your exterior lighting travels into the steering column to the turn signal cam and then back out.
Old Apr 30, 2005 | 03:40 PM
toyvet1's Avatar
toyvet1
I was able to trace all the problems down to corrosion in the fuse box, Cleaned and replaced all fuses and everything in life is good again..
To 79 dash ground
