I need a trailing arm measurement
Old Apr 29, 2005 | 10:11 AM
magicv8's Avatar
magicv8
Default I need a trailing arm measurement
Could someone please tell me the distance from the center of the spindle (hole) to the center of the frame anchor bolt (hole)?
I am checking a rear wheel alignment at home, and I need to know how much tire movement (toe in) occurs when shims are moved at the anchor bolt.
Old Apr 29, 2005 | 01:34 PM
Twin_Turbo's Avatar
Twin_Turbo
I can check it for you in a couple of hours, I have some arms lying around at home.
Old Apr 29, 2005 | 03:17 PM
FLEXUSMARK's Avatar
FLEXUSMARK
This is what I measured.
The distance is 17-3/8" from the center of the spindel to the center of the anchor bolt.
A 1/8" shim translates into 4.12 deg.
Hope this helps.
Mark.
Old Apr 30, 2005 | 10:18 PM
magicv8's Avatar
magicv8
Thanks Mark - love the pic
Old May 3, 2005 | 08:29 AM
magicv8's Avatar
magicv8
Using these dimensions, I aligned the rear end to .0675 toe in on the first pass, with the thrust angle 1.1degree left. I am undecided on whether to correct the thrust angle to zero by moving .095inch of shims from right to left on both arms. If I do, the car is "correct", but will change lanes to the left when I power shift. I am thinking about giving up straight line rubber in all four gears - in favor of "correct" alignment.
To I need a trailing arm measurement
