Found torque specs for front end
Old Apr 30, 2005 | 07:47 AM
SanDiegoPaul's Avatar
SanDiegoPaul
From: San Diego - Deep Within The State of CONFUSION!
Default Found torque specs for front end
In my Assembly manual, for 1976:
Upper BJoints 40-60 Foot Pounds
Lower BJoints 70-90 Foot Pounds
Lower Control arm Bush 45-55 Foot Pounds
Upper bushings no spec shown but probably same as lower
Old Apr 30, 2005 | 08:04 AM
Jughead's Avatar
Jughead
Senior Member since 1492
From: Just because I'm paranoid doesn't mean people aren't out to get me...
St. Jude Donor '09
I usually look there last
If you replaced the spring, don't torque the CA bushing bolts until you have weight on the front end.
Old Apr 30, 2005 | 08:52 AM
wills670's Avatar
wills670
are the upper control arm bolts the same size as the bottom i thought they were smaller? if smaller dia. it should have a lighter tourqe.
did you have any luck with your grease fitting?
Old Apr 30, 2005 | 11:14 AM
SanDiegoPaul
Yea they could very well be smaller - I was just guessing I didn't look yet. RE the grease fitting - no not yet darn it. I tried again three times and no joy.
I did get the fitting in far enough to put grease in the joint -WHOPEEE but when I took the grease gun off the fitting, it came right out.
Old Apr 30, 2005 | 11:17 AM
Cali,68,L-79's Avatar
Cali,68,L-79
25ftlbs according to Speeddirect.com
Old Apr 30, 2005 | 11:18 AM
mandm1200's Avatar
mandm1200
I was going to look at the AIM last night, but it was out in the garage and it was 1AM and the Chilton was on the computer desk. The spec's and installation instructions should come with the kit. I could see if your buying just one ball joint from the local parts store, but I expect buying from 'our' vendors they would include all necessary information: to assemble the part(s) correctly, hints, tips, etc.
Old Apr 30, 2005 | 12:11 PM
SanDiegoPaul
Well the control arms from VanSteel were complete. Ball Joints rived in already, and busings inplace too, with new control arm shafts. The only thing seperate was the little bag with the rubber dust cap, cotter pin and grease zerk for each ball joint.
Three of the zerks went in just fine but that right upper ball joint just won't take one.
VanSteel DAN are you there?
Old Apr 30, 2005 | 01:06 PM
SanDiegoPaul
Yea it's funny. I woke up 4AM thinking that I just KNEW
I had the ways and means here in my home office to find that info. I've got the old 1976 Motor's Manual, I've got a couple of early '80s Chiltons, and of course GOOGLE
Then I remembered that I had the assembly book. I always think of it as nothing more than pictures and rarely look at it for anything of value
To Found torque specs for front end
