Chrome Molding around the Windshield Question
How do you take off the chrome moldings around the windshield? Tricks or tips please.
windshield. It had delaminated over the 30 plus years.
First you must remove the side stainless in front of the side glass,
inorder to do this you must remove the weather strip. There will
be screws to remove, and then you need to carefully pull the trim
out once the screws are out. The factory puts a black substance
on the stainless to help seal it to the glass, so it might give a little
resistance. The header trim on top of the windshield may or may
not come off in one piece due to rust in the winshield frame. It is held
in by clips that span across the top frame. Mine was distroyed when
I pulled it off, I had to purchase a new one, and my clips on the wind
shield frame had to be replaced. The clips cannot be replaced unless
you pull the windshield. Its best to have a professtional install a new
windshield as your need a power applicator to put a straight bead of urethane on when installing new glass, and properly prepping to insure the glass doesnt come loose in time. also dont forget the rubber spacer
blocks. A factory shop manual, and a corvette assembly manual would
help.
