Lifter Stuck in it's Bore!!!!
Old Apr 30, 2005 | 09:41 PM
Kid Vette's Avatar
Kid Vette
Default Lifter Stuck in it's Bore!!!!
I'm in the process of swapping cams. One lifter won't come out of it's bore. I can pull it up about a half an inch and then its like it hits a dead stop! The only thing I can think of is that its flared out on it's base. So how do I get it out. I'm thinking maybe I can pull it up as far as it will go and then cut off the part that is exposed. Then maybe I can get the rest out thru the cam bore.
Ideas?
Old Apr 30, 2005 | 09:45 PM
yellow 72's Avatar
yellow 72
St. Jude Donor '09
There is a lifter puller tool, looks like a little slide hammer for tight lifters.
Depending on how mushroomed it is that might work.
Old Apr 30, 2005 | 10:05 PM
Kid Vette's Avatar
Kid Vette
I don't think I want to force out. I'm afraid I'll damage the bore which means I'll need a new block!
It comes up the first half inch very freely and then its just like it hits something.
Old Apr 30, 2005 | 10:19 PM
stingry's Avatar
stingry
St. Jude Donor '05-'06
I know you are worried about damaging the block getting the lifter out but it may already be damaged, otherwise the ilfter would come out right?
Any way you can sand/file with a dremel the lifter edge from where you can see it to reduce its size? You then have a problem of metal filings in the engine which is also ugly.
Man what a conundrum!
Hope you can fix it.
Pete
Old Apr 30, 2005 | 10:32 PM
marshrat99's Avatar
marshrat99
Don't get excited. Probably just tarnish keeping the lifter from coming out. Just get some cheap break cleaner and keep squirting the lifter while you move it up-down and left-right. If this doesn't do the trick, then the bottom of the lifter is screwed. You'll have to drop it down to the cam area of the motor. Good luck.
Old Apr 30, 2005 | 10:46 PM
yellow 72's Avatar
yellow 72
St. Jude Donor '09
Problem with that is...if you can't remove the lifter, you can't remove the cam to drop the lifter out the bottom
Old Apr 30, 2005 | 11:07 PM
kens 80's Avatar
kens 80
Buy or borrow the lifter puller, I have done many this way and you will not hurt the bore. The fine edge if the lifter will flatten out as its pulled.
Old Apr 30, 2005 | 11:59 PM
Lotus76's Avatar
Lotus76
Default Don't Worry
Kid Vette,
Marshrat 99 is probably correct. It is varnish. I had the same problem last month when I changed my cam & lifters. Only I had almost all of them that didn’t want to come out
Here’s my advice, I used kroil but any good penetrating oil will work like marvel, PB blaster, liquid wrench ect.. Spray the block / lifter and work the lifter up and down and around (very important to go up and down this gets the penetrating oil down in the lifter bore) you will start to feel it getting easier and start coming out farther. Be patient and keep working it.
Good luck
John
Old May 1, 2005 | 12:00 AM
Kid Vette's Avatar
Kid Vette
All the lifter pullers I can find online say hydraulic lifter puller. My old lifters are solids. Will they work?
Old May 1, 2005 | 12:06 AM
Jclgodale3's Avatar
Jclgodale3
if it's the last lifter in and you say you can move it up off the cam lobe but it won't come completely out...hold the lifter up and slowly remove the cam. THEN you can let the lifter drop through the bottom of the bore...correct?
Old May 1, 2005 | 01:11 AM
72rdstr's Avatar
72rdstr
Originally Posted by Lotus76
Kid Vette,
Good luck
John
Old May 1, 2005 | 10:11 PM
kens 80's Avatar
kens 80
The lifter tool works on all but rolller lifters and I have never seen a roller lifter get stuck.
Old May 2, 2005 | 10:12 AM
Solid LT1's Avatar
Solid LT1
If you can pull it out a 1/2 inch, you can put some Vice Grips on that sucker and get it all the way (comming from a guy who has destroyed more than 1 of the "trick" lifter pulling tools in his life.)
Old May 2, 2005 | 10:57 AM
yellow 72's Avatar
yellow 72
St. Jude Donor '09
I've only had to use it a couple times, but if you take your time and use some penetrant it will work well.....
Old May 2, 2005 | 01:07 PM
Kid Vette's Avatar
Kid Vette
Thanks for all the input everybody! I guess the consensus is that I can yank that thing out without destroying the bore?
I've decided that I'm going to pull the engine now anyway. I got antifreeze in the crankcase last fall the last time I drove it. See Drove Vette to Work, Brought It Home On a Flatbed . From what I have been hearing about antifreeze eating up bearing material and now this, I think I'll just go through the whole thing
Old May 2, 2005 | 02:59 PM
Hvymtlc5's Avatar
Hvymtlc5
I agree with JCLGODALE3...no special tool needed. Pull th lifter up with whatever your using (magnet) and pull the cam. Push the lifter pout the bottom
Old May 2, 2005 | 03:07 PM
pws69's Avatar
pws69
Kid Vette,
Good luck
John
I have also found that Carb Cleaner is good for this task. A little harsher and disolves the varnish better.
To Lifter Stuck in it's Bore!!!!
