Was This Block Cleaned Before Assembly??
Old May 2, 2005 | 10:12 PM
nastee383's Avatar
nastee383
Default Was This Block Cleaned Before Assembly??
Does it look like this block was hot tanked or otherwise cleaned internally before assembly? There is alot of rust/scale in the water passages. I don't remember the shortblock I bought several years ago looking this nasty inside.
Old May 2, 2005 | 10:33 PM
turtlevette's Avatar
turtlevette
St. Jude Donor '03,'11
it sure don't look like it was hot tanked.
Old May 2, 2005 | 10:38 PM
GrandSportC3's Avatar
GrandSportC3
Cruise-In IV-V-VI-VII-VIII Veteran
St. Jude Donor '03, '06, '17
I don't even know what hot tanking is
What effects does it have if it was not done?
Old May 2, 2005 | 11:06 PM
BigBlockk's Avatar
BigBlockk
Hot tanking is a chemical cleaning process where the block , heads and intake manifold (and just about whatever else you want) is immersed in a tank of cleaning solvents and boiled. To do a really good job you let them cook it all weekend. By the way you need to take out all soft metal (cam bearings, freeze plugs) because this process will dissolve them.
BigBlockk
Later.....
Old May 2, 2005 | 11:33 PM
comp's Avatar
comp
Old May 2, 2005 | 11:42 PM
Jclgodale3's Avatar
Jclgodale3
when my block was hot tanked then bored...it started developing surface rust in the lifter valley area and a few other spots before I decided to mist it with WD-40 while the build was taking place. Hot tanking will take ALL the oil residue off the cast iron and things will start to rust if not oiled. Doesn't confirm your block was hot tanked though...just MO
Old May 3, 2005 | 01:42 AM
88'Cubka's Avatar
88'Cubka
St. Jude Donor '08
We just had our 350 block hot tanked and the water passages were still scaled. It is really hard to tell whether it has just been cleaned really well or boiled..
Old May 3, 2005 | 01:52 AM
Carl Granquist's Avatar
Carl Granquist
Let me ask this: I have a small radiator leak and am getting ready to add "Bar's Leaks" radiator stop leak. Will I end up with scale and residue like this that's harmful?
Old May 3, 2005 | 05:59 AM
Jughead's Avatar
Jughead
Senior Member since 1492
From: Just because I'm paranoid doesn't mean people aren't out to get me...
St. Jude Donor '09
Mine was tanked (dipped) then washed among other things. The inside looked like the pic(surface rust). The external areas I had to immedicately coat with WD-40 until I was ready for paint.
I don't see how the internal (inside the block)surface rusting can be prevented.
Here's my block the day I brought it home.
Old May 3, 2005 | 07:40 AM
bobs77vet's Avatar
bobs77vet
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
no not scale and rust, just lumpy gooey crude.....and a heaster core that doesn't flow so well (maybe not a bad thing).....don't do it.....have it fixed....
Old May 3, 2005 | 08:17 AM
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
That's as good as it gets. If you are taking that motor apart for inspection, might as well take it down to bare block and check main and rod clearances and cylinder bore size, taper roundness etc. Visual inspection will pick up the obvious but you need to measure all this stuff then you will know what you are dealing with and you will know the the torque settings are correct when you assemble.
Old May 3, 2005 | 08:23 AM
norvalwilhelm's Avatar
norvalwilhelm
Hot tanking is not what it use to be. The use of costic solutions due to pollution is a thing of the past here. They use a much milder solution, friendly to the environment and a large industrial dish washer. It doesn't do a good job on the internal water passages.
Old May 3, 2005 | 08:28 AM
page62's Avatar
page62
DON'T use Bars Leaks...please! It is made of ground coconut shells and has the potential to clog your heater core, among other things. If you must use a radiator stop-leak product, use Aluma-Seal or a similar product.
Old May 3, 2005 | 10:55 AM
Wrencher's Avatar
Wrencher
The only way to really get the rusty crud out is media blasting. Our caustic soda hot tank does a great job, but rust is rust and it won't get rid of it entirely, just the loose stuff. I don't worry about it, I just use a quality antifreeze with a bit of soluable oil mixed in, and then change it at least annually.
Hans
Old May 3, 2005 | 11:52 AM
Tom454's Avatar
Tom454
Old May 3, 2005 | 01:20 PM
nastee383's Avatar
nastee383
Thanks for all the replies. I guess it's not that big of a deal. Just looks bad.
Old May 3, 2005 | 04:18 PM
Chuck Gongloff's Avatar
Chuck Gongloff
Active Streak: 90 Days
Stole my thunder. In Maryland, with the EPA and MOSH (MD Occ. Safety/Health), hot tanking is a thing of the past.
Used to use caustic lye. Now, every shop I've seen uses the large "industrial size" dishwasher. Chuck
To Was This Block Cleaned Before Assembly??
Old May 3, 2005 | 05:08 PM
joe73vette's Avatar
joe73vette
My block was "shake and baked", where they put it in an oven overnight and then media blast it. The water passages looked like new when I got it. Joe
Old May 3, 2005 | 06:44 PM
79VetteMike's Avatar
79VetteMike
When I got my 400 back from the machine shop, i was less than happy. I told them that I definately wanted it hot tanked, but it only looked like they washed the outside of the block. They said, that's the best you get these days, but he didn't really go into detail. Anyway, I had it acid dipped too and it still didn't look good. There is still alot of rust crud in the water passages. I sprayed PB Blaster in there and used a wire brush where I could. I thought about media blasting it, but didn't want to keep dumping money into it. I'll just run some radiator flush when I get it all back together.
Old May 3, 2005 | 07:17 PM
jimcork1's Avatar
jimcork1
Bare iron that has been stripped of any coating will rust with a power coat very quickly. This should not be an issue. Even if it was "Hot tanked" the rust will form very quickly. I would not expect this to be an issue. When you add coolant the rust protection will stop further problems. So now.. finish it,, add water, and lets go to the track. 99 Nassau Blue
