Poly bushing squeak
Old May 4, 2005 | 01:28 PM
Biker's Avatar
Biker
Melvin, since your bushings are already installed, spray them liberally with silicone lubricant. Unlike oils and solvents, silicone will not damage poly. In addition, it will outlast Armour All, which is water-based.
Old May 4, 2005 | 01:33 PM
DJ Dep's Avatar
DJ Dep
St. Jude Donor '05-'07
Originally Posted by Mike Ward
This may or may not be true, but how many people actually drive their Corvette at the limit on the street? If so, how do you find enough money to pay for the speeding and dangerous driving tickets?
While I agree with your point 100%, I think, unfortunately, the answer is "way too many" drive their Vettes to the limit on the street. I've said this same thing before and been pounced on for it...."Performance driving" belongs at a TRACK.
Dep
Old May 4, 2005 | 01:45 PM
Biker's Avatar
Biker
Dep
The street is my track.
Old May 4, 2005 | 01:52 PM
DJ Dep's Avatar
DJ Dep
That's brilliant. At least when some yuppy soccermom plows into you while you're doing some track manuver on the street, I live close enough to you to bid on whatever is left of your Vette
Dep
Old May 4, 2005 | 01:57 PM
mandm1200's Avatar
mandm1200
Things have changed way too much to 'race' on the streets and highways now a days. Way too much traffic to even consider it. Maybe I am getting older and more conservative, but I like to think I am wiser now. I do not want my daughter, myself, or anyone for that matter being injured due to someone driving in an unsafe manner.
Old May 4, 2005 | 09:57 PM
LiveandLetDrive's Avatar
LiveandLetDrive
I had some swaybar squeaks at one point but the (very) occassional spray silicone or whatever eliminated that. Stiffer ride? Maybe if you are "sensitive." Nothing I've noticed, even before I put in the springs I have now.
Is this turning into a streetracing thread? More to the point, at the limit has nothing to do with it. Handling is more precise throughout the range, unless you drive like a granny you will notice a difference. And I hope your car can handle precisely at the limit when that yuppie soccermom tries to plow into you. Which brings me to the reason I think every competent driver should autocross...
Cost difference is negligible also. Rubber didn't hold up for 25 years, that's just when we decided to replace our long-since-wornout rubber.
Now I drive pretty spiritedly, but I'm not gonna back you up on that one!
-Chris
Old May 4, 2005 | 10:07 PM
DJ Dep's Avatar
DJ Dep
-Chris
Well call me granny
Dep
Old May 9, 2005 | 10:03 PM
1SLANDON's Avatar
1SLANDON
Have you checked your shocks? Maybe you have a dead one. Does the sound increase when you go around a corner?
Old May 10, 2005 | 08:18 AM
MELVINJ's Avatar
MELVINJ
Sound doe snot increase when going around a corner. Only over straight line bumps does it sqweak
Old May 10, 2005 | 08:54 AM
Vette_Tech's Avatar
Vette_Tech
Simply place a washer between the sway bar bushing strap and the frame, this will stop 90% of poly squeeks!
