Some Dumb Carb Questions
Old May 3, 2005 | 03:13 PM
73 red vette's Avatar
73 red vette
Gerry
excellent, back to basics so i know what i have. great piece of info to get me on the right trail
thanks a lot
R
Old May 3, 2005 | 03:24 PM
73 red vette
Gerry,Gary. Tom and the rest of you Vette Gurus,
i want to thank you, i think i just learned more here in an hour or so than i learned in my short 63 years on this earth, with regards to carbs and tuning, anyhow,now i have to put everything you taught me to work if this pea brain can remember it all.
thank you guys
R
Old May 3, 2005 | 05:19 PM
Kid Vette's Avatar
Kid Vette
Just to confirm; your carb should look like this (except yours doesn't have the electric choke):
A couple links that might help.
HOLLEY CARBURETOR MODEL 4150 / 4160
Rebuild and Adjustment Instructions
Old May 4, 2005 | 09:28 AM
73 red vette
No it doesn't it is a lot different. it has the gas line hook up on the same side as the choke.1 in the front and 1 in the rear, it has the Holley name on the front and rear gas connections. the adjustment screw on top of the bowl is in the center, it is similar but not the same. remember it's probly an old carb,real old. i haven't been able to find a pic of it anywhere and my digital is out of service or i'd post a pic of it. It has really been screwed up by the previous owner(s). the throttle is connected to the carb rear by a makeshift bracket and when i try WOT it can't because the throttle hits the bracket and won't allow all four barrels to open up. the rear carb hole that the throttle bracket connects to had been stripped out of the manifold and a mickey mouse bolt had been put in there . they must have rethreaded it to a larger size to accommodate the new bolt. i got a lot of fixin to do on this carb and manifold.
thanks for the links
R
Old May 4, 2005 | 11:58 AM
73 red vette
kidvette
if you can pull up this pic this is what my carb looks like will trym to post link
http://www.holley.com/HiOctn/ProdLin...s/f0-4779C.jpg
Old May 4, 2005 | 12:03 PM
comp's Avatar
comp
big difference
Old May 4, 2005 | 12:16 PM
73 red vette
even that pic has some differences to it but it's as close as i can find
Old May 4, 2005 | 12:41 PM
Tom454's Avatar
Tom454
The 3310-2 you have may have been modified. It is supposed to be a model 4160 which has a primary metering block between the front fuel bowl and the main body, and no metering block between the rear float bowl and the main body.... just a metering plate, inside the bowl where you cannot see it.
I know you said the pic is not correct, but here is some more info...
The pic you have is of a 4150... metering blocks between both float bowls and the main body.
3310-1 was a 4150,
3310-2,3,4,5,6 were all 4160's.
The pic also shows center hung floats (bowls) as opposed to side hung floats.
Also... some float bowls have the casting for a fuel inlet connection, but are not machined or threaded. So although it may look like it has fuel connections at both bowls, only one is functional.
Lots of variables here... and Holleys claim to fame is its "modularity".... lots of parts to mix & match.
We'll all be like the blind men and the elephant though unless we see a pic.
Need to fix that digital camera... yeh.
Tom
Old May 4, 2005 | 01:59 PM
73 red vette
Tom
right you are, the guy that had this car, or someone must have though he was a mechanical genius. Boy are things on this car messed up . it has 2 fuel connections on front and rear, only the 2 on pass. side are machined for threads. probly will opt for a new carb if i can get one that's road ready out of the box.
any suggestions would be appreciated
R
Old May 4, 2005 | 02:06 PM
Tom454's Avatar
Tom454
Were both inlets plumbed for fuel? i.e.- does it have a dual feed fuel line currently installed?
I can fax you what I have on the 3310-2.... IM me if interested & provide a fax number.
Old May 4, 2005 | 02:19 PM
73 red vette
yep both inlets are plumbed and it does have dual feed line installed.
don't have a fax,but if possible you could email them to:
vet78us@yahoo.com
i really appreciate everyones help on this
R
