Rag joint - Best Know method
Old May 3, 2005 | 07:38 PM
theandies's Avatar
theandies
Default Rag joint - Best Know method
I am going to replace my rag joint and I would like to know the best method to get it off the steering rod. Is it better to loosen or remove the steering box or loosen the column under the dash to separate the rods? How far do the rods have to be apart to take the joint out? As you can guess I am trying to do this the fastest way without removing a lot. Car: 1971 350SB without PS.
Old May 3, 2005 | 07:47 PM
Burgundy 69's Avatar
Burgundy 69
Just did this. After trying both methods, we settled on dropping the steering column. Remove the two bolts at the dash and two more on the fire wall. This allows the column to slide forward.
I would suggest that you remove the bolts at the joint first. Mine required a lot of tugging and it would have been much harder to do if the column were flopping around.
Mark
Old May 3, 2005 | 09:11 PM
SkunkApe's Avatar
SkunkApe
Unbolting the steering box is much easier than screwing with the steering column.
Old May 3, 2005 | 10:07 PM
bobs77vet's Avatar
bobs77vet
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
start soaking the nuts and bolts ASAP....we had a bear getting it out with the engine out and the gear box almost disconnected..
Old May 3, 2005 | 11:38 PM
TXShark's Avatar
TXShark
I took the steering column out (loosened it), but I think loosening the steering box would have been easier. It's a little backbreaking. Good luck.
Old May 3, 2005 | 11:46 PM
Uncle Ralphy's Avatar
Uncle Ralphy
I did this about 4 months ago. I removed the steering box. It wasn't a hard job.
Old May 4, 2005 | 12:57 AM
GDaina's Avatar
GDaina
I'm with the steering box crowd...getting under the dash to get at the bolts then back under and tightening...no thanks...the box is easier to reach...
Old May 4, 2005 | 05:43 AM
theandies's Avatar
theandies
Steering box it is. Thanks everybody.
Old May 4, 2005 | 06:05 AM
73jst4fun's Avatar
73jst4fun
Let us know how you make out, I see that task coming up for me soon..
Old May 4, 2005 | 08:06 AM
Edzred72's Avatar
Edzred72
Originally Posted by bobs77vet
start soaking the nuts and bolts ASAP......
Eddie
Old May 4, 2005 | 01:34 PM
Biker's Avatar
Biker
My Chilton's manual says to remove the streering column. No mention of steering box removal. Is a puller required to remove the (2) rag joint flanges from the steering shaft, or do they readily come off?
Old May 4, 2005 | 01:41 PM
NHvette's Avatar
NHvette
They should readily come off - unless caked with rust.
In order to "properly" install and align the coupler, the steering
column needs to move. If properly aligned to begin, then you
can probably get away fine with dropping the box. Then, it comes
down to whether you prefer a cricked neck or black greasy hands.
Good luck.
Old May 4, 2005 | 01:51 PM
captainmorgan's Avatar
captainmorgan
What all is involved in removing the steering box?
To Rag joint - Best Know method
