#4 body mounts
Old May 3, 2005 | 11:50 PM
CFL34's Avatar
CFL34
Cruising
Default #4 body mounts
[SIZE=3]3[/S IZE] #4 body mounts are rusted just spinning around is the best option to cut them with a sawzall? was wondering if i put a set of vise grips on the nut inside the body then got underneath and tried wrenching on it again???? any help from experience is appreiciated
Old May 4, 2005 | 01:54 AM
Jclgodale3's Avatar
Jclgodale3
cut it off with a 4" grinder/cutter
Old May 4, 2005 | 06:32 AM
redwingvette's Avatar
redwingvette
The nut is a square nut and becaus it is down in a pocket. All it did was spin with the Vise-grips anyway. Cut it off.
Old May 4, 2005 | 06:57 AM
stingry's Avatar
stingry
St. Jude Donor '05-'06
Cutoff the bolt end from the bottom with a cutoff wheel. Hit it with a punch to push past the cage nut and then pull it out from the top.
Did this about 3 weeks ago. Replace the cage nut with a nut welded to a plate teh same size as the cavity it fits in OR get hold of a new cage nut and rivet it in.
Old May 4, 2005 | 07:56 AM
Edzred72's Avatar
Edzred72
That's what I did too. I don't think you can rivit a new cage in with the body on so I used a large washer & nut inside the body. GM uses grade 5 steel in those body mount bolts. Good stainless has the same tensil strength as grade 5 steel, so I used stainless for mine. Just grind a point onto the end for ease of install.
Eddie
Old May 4, 2005 | 12:55 PM
NHvette's Avatar
NHvette
I have some pics of the area of concern:
http://forums.corvetteforum.com/show...960&forum_id=3
... and a previous post working the other side:
http://forums.corvetteforum.com/showthread.php?t=872065
How to take on the frozen #4:
Good luck
Old May 4, 2005 | 02:58 PM
iree75's Avatar
iree75
Check out my pics link to see a couple of pics on my #4 mounts. I did all the mounts at once. I agree with the rest.. I used a 4'' grinder, drill, punch and my 8 yr old son to crawl in and get the old cage nut out. I used pop rivets with backing plates (heres where once again my son came in handy) and fiberglass filler to make sure there were no leaks and that the plates fit well on the body.
-F
Old May 4, 2005 | 05:20 PM
CFL34's Avatar
CFL34
Cruising
Good luck
looks easy enough what type of stainless bolts are those with the rounded heads also where do you get that urethane adhesive??
Old May 4, 2005 | 05:23 PM
CFL34's Avatar
CFL34
Cruising
thanks to everyone i really thought this job was going WAY too easy till thi is problem i'll get her off soon thanks again!!!
Old May 4, 2005 | 05:30 PM
NHvette's Avatar
NHvette
Stainless button-head 1/4-20x3/4" bolts in the drawers at Home Depot.
I'm sure any good hardware store should have something comparable.
The PL urethane adhesive is readily available at Home Depot, also.
http://NHvette.com/ftp/_pictures/vet...PLadhesive.jpg
If uncomfortable with this, get 3-M Window Weld at good parts/body/paint stores.
Old May 4, 2005 | 08:44 PM
matchframe's Avatar
matchframe
I had to do the same.
Great idea about welding a nut to a plate the same size as the cavity!!
www.bigdogvettes.com
Old May 4, 2005 | 09:52 PM
gearheaddroppings's Avatar
gearheaddroppings
St. Jude Donor '05-'06-'07-'08-'09-'10
[QUOTE=NHvette]I have some pics of the area of concern:
Good luck
This is how I did it. I used a Makita 4 inch grinder. Took that sucker right off. I'm getting an eye twitch from the memories!!!!
To #4 body mounts
